StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M
Quicklinx: 8BLXWS00 Mfr#: MDP2DPMM4M
41 In Stock
£19.60 ex VAT
£23.52 inc VAT
Connect your Mini-DisplayPort-equipped computer to a standard DisplayPort monitor. The MDP2DPMM4M 4m Mini DisplayPort to DisplayPort Cable features a Mini DisplayPort (male) connector on one end, and a DisplayPort (male) connector on the other, enabling you to connect your Mini DisplayPort-equipped laptop or Mac family of products to a monitor or projector that uses a standard DisplayPort connection.
  • Durable construction
    The cable features aluminum mylar foil with braid shielding, ensuring long-lasting performance while protecting against interference.
  • Gold-plated connectors
    Each connector is gold-plated to provide enhanced conductivity, reducing the risk of signal loss and ensuring high-quality transmission.
  • Wide compatibility
    This adapter cable is compatible with Mac devices, allowing users to extend or mirror their displays easily.
  • Flexible length
    At 4 meters, this cable allows for versatile setups, making it suitable for various configurations without compromising video quality.
  • High-quality video and audio
    Designed for optimal performance, this adapter delivers superior video and audio output for a seamless experience.
StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M - 4m Mini DisplayPort to DisplayPort - Mini DP to DP Cable (MDP2DPMM4M) - DisplayPort cable - 4 m
DisplayPort cable
Shielded
Length
4 m
Connector
Mini DisplayPort - male
Connector (Second End)
DisplayPort - male
RoHS
P/N: CDP2MDP, CDP2MDPEC, CDP2MDPFC, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDMDP, HD2DP
DisplayPort cable
Shielded
Shielding Material
American Wire Gauge (AWG)
32
Plated Connector
Gold
Length
4 m
Connector
20 pin DisplayPort - male
RoHS
8BLX StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.27
8BLX StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F In Stock £14.83
8BLX StarTech.com 1m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.82
8BLX StarTech.com 2m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £11.02
8BLX StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M In Stock £19.60
8BLX StarTech.com 3m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £13.58
