StarTech.com 4K HDMI Extender, 4K 60Hz HDR
Quicklinx: H2THWS00 Mfr#: 4K70IC-EXTEND-HDMI
Hurry, only 3 left in stock!
£165.60 ex VAT
£198.72 inc VAT
This HDMI Extender transmits a 4K 60Hz HDMI audio video signal up to 230ft (70m) over Category 5e/6 Ethernet Cabling. The converter kit includes the transmitter and receiver units for a complete point-to-point solution.
  • 4K 60Hz Resolution
    This HDMI extender supports resolutions of up to 4K 60Hz with zero latency over a single Ethernet cable. The UHD HDMI Extender supports HDMI 2.0 and 4:4:4 chroma subsampling, which ensures clear and stable video output.
  • Power-Over-Cable
    Connect the power adapter to the transmitter or receiver to power both units, using Power-over-Cable (PoC). Use an IR remote control to communicate with the source device, from the location of the receiver unit, using the IR extension kit.
  • Versatile Installation Options
    The 4K HDMI Extender features an HDMI output on the transmitter unit, enabling the connection of an HDMI display or to connect additional video extenders - to establish a cascade connection. Plug-and-play installation with no additional software or drivers required. Attach the mounting brackets to the metal housing and to a wall, ceiling, or to the underside of a table, facilitating a multitude of professional installation options. The rubber feet protect the mounting surface and isolate the units from vibration. This product is backed for 2-years, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 4K HDMI Extender Over CAT5/CAT6 Cable, 4K 60Hz HDR Video Extender, Up to 230ft (70m), HDMI Over Ethernet Cable, S/PDIF Audio Out, HDMI Transmitter and Receiver Kit - Local Video Out, Power Over Cable (4K70IC-EXTEND-HDMI) - video/audio/infrared extender - HDMI
Video/audio/infrared extender
External
HDMI
Transmission Medium
CAT 5/5e/6/6a
Max Transfer Distance
70 m
Power Over Ethernet (PoE)
PoC
AC 100-240 V
9.9 cm x 10.6 cm x 2.6 cm
210 g
External
Wired
HDMI
Max Resolution
3840 x 2160 @ 60 Hz
70 m
Status Indicators
Reset button, 7.1 channel audio support, metal housing, DTS support, 8KV ESD Protector (air-gap discharge), Dolby Digital support, daisy-chaining support, HDR support, 6KV ESD Protector (contact discharge), 4:4:4 chroma subsampling support, zero latency, IR control, audio input selector
HDCP 2.2
1 x HDMI output (local unit) - Type A female , 1 x HDMI input (local unit) - Type A female , 1 x network (local unit) - RJ-45 female , 1 x IR output (local unit) - phone 3.5 mm female , 1 x HDMI output (remote unit) - Type A female , 1 x network (remote unit) - RJ-45 female , 1 x IR input (remote unit) - phone 3.5 mm female , 1 x SPDIF (remote unit) - TOSLINK
IR receiver, 8 rubber feet, mounting kit, IR blaster extension cable
Plug and Play, RoHS, WEEE, RCM
PoC
External power adapter
AC 100-240 V
0.1 Watt
9.9 cm
10.6 cm
2.6 cm
210 g
Shipping Width
24 cm
Shipping Depth
17.6 cm
Shipping Height
8 cm
Shipping Weight
900 g
Limited warranty - 2 years , Technical support - assistance - lifetime
-20 °C
60 °C
0 - 90% RH (non-condensing)
H2TH StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
H2TH StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £16.00
H2TH StarTech.com 3m 10ft Premium HDMI 2.0 Cable In Stock £20.46
H2TH StarTech.com HDMI Extender over CAT6 4K PoC In Stock £96.83
H2TH StarTech.com HDMI Extender, 4K 60Hz, 200ft In Stock £109.90
