This HDMI Extender transmits a 4K 60Hz HDMI audio video signal up to 230ft (70m) over Category 5e/6 Ethernet Cabling. The converter kit includes the transmitter and receiver units for a complete point-to-point solution.
4K 60Hz Resolution
This HDMI extender supports resolutions of up to 4K 60Hz with zero latency over a single Ethernet cable. The UHD HDMI Extender supports HDMI 2.0 and 4:4:4 chroma subsampling, which ensures clear and stable video output. -
Power-Over-Cable
Connect the power adapter to the transmitter or receiver to power both units, using Power-over-Cable (PoC). Use an IR remote control to communicate with the source device, from the location of the receiver unit, using the IR extension kit. -
Versatile Installation Options
The 4K HDMI Extender features an HDMI output on the transmitter unit, enabling the connection of an HDMI display or to connect additional video extenders - to establish a cascade connection. Plug-and-play installation with no additional software or drivers required. Attach the mounting brackets to the metal housing and to a wall, ceiling, or to the underside of a table, facilitating a multitude of professional installation options. The rubber feet protect the mounting surface and isolate the units from vibration. This product is backed for 2-years, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com 4K HDMI Extender Over CAT5/CAT6 Cable, 4K 60Hz HDR Video Extender, Up to 230ft (70m), HDMI Over Ethernet Cable, S/PDIF Audio Out, HDMI Transmitter and Receiver Kit - Local Video Out, Power Over Cable (4K70IC-EXTEND-HDMI) - video/audio/infrared extender - HDMI
- Video/audio/infrared extender
- Form Factor
- External
- Data Link Protocol
- HDMI
- Transmission Medium
- CAT 5/5e/6/6a
- Max Transfer Distance
- 70 m
- Power Over Ethernet (PoE)
- PoC
- Power
- AC 100-240 V
- 9.9 cm x 10.6 cm x 2.6 cm
- 210 g
- 2-year warranty
- Form Factor
- External
- Black
- Connectivity Technology
- Wired
- HDMI
- Max Resolution
- 3840 x 2160 @ 60 Hz
- 70 m
- Status Indicators
- Power
- Reset button, 7.1 channel audio support, metal housing, DTS support, 8KV ESD Protector (air-gap discharge), Dolby Digital support, daisy-chaining support, HDR support, 6KV ESD Protector (contact discharge), 4:4:4 chroma subsampling support, zero latency, IR control, audio input selector
- HDCP 2.2
- 1 x HDMI output (local unit) - Type A female , 1 x HDMI input (local unit) - Type A female , 1 x network (local unit) - RJ-45 female , 1 x IR output (local unit) - phone 3.5 mm female , 1 x HDMI output (remote unit) - Type A female , 1 x network (remote unit) - RJ-45 female , 1 x IR input (remote unit) - phone 3.5 mm female , 1 x SPDIF (remote unit) - TOSLINK
- Included Accessories
- IR receiver, 8 rubber feet, mounting kit, IR blaster extension cable
- Plug and Play, RoHS, WEEE, RCM
- PoC
- Power Device
- External power adapter
- Voltage Required
- AC 100-240 V
- 0.1 Watt
- 9.9 cm
- 10.6 cm
- 2.6 cm
- 210 g
- Shipping Width
- 24 cm
- Shipping Depth
- 17.6 cm
- Shipping Height
- 8 cm
- Shipping Weight
- 900 g
- Limited warranty - 2 years ¦ Technical support - assistance - lifetime
- -20 °C
- 60 °C
- 0 - 90% RH (non-condensing)
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £11.32 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £18.49 |
StarTech.com 3m 10ft Premium HDMI 2.0 Cable | In Stock | £20.46 |
StarTech.com HDMI Extender over CAT6 4K PoC | In Stock | £96.83 |
StarTech.com HDMI Extender, 4K 60Hz, 200ft | In Stock | £109.90 |
