This 4K HDMI audio extractor lets you de-embed the audio from your HDMI video streams to create a distinct audio output that you can connect directly to a digital or analog audio device. Supporting HDMI 2.0 specifications, the de-embedder maintains 4K 60Hz resolutions to deliver a seamless video experience.
The HDMI sound splitter supports video resolutions up to 4K 60Hz (3840 x 2160) and high video bandwidth up to 18Gbps. It also supports High Dynamic Range (HDR) video pass-through, letting you enjoy lifelike images with incredible contrast, brightness and color, and greater luminosity compared to standard digital imaging.
Easily integrate HDMI 2.0 devices, such as your new 4K Blu-ray player, with your existing audio equipment or desktop speakers. The extractor isolates and extracts the audio signal from your HDMI cable and lets you output to digital optical audio or dual RCA audio devices. The integrated EDID management capabilities support 2-channel, 5.1-channel and pass-through audio modes.\
The HDCP compliant HDMI audio de-embedder is compatible with dual-RCA composite adapters, giving you the flexibility to integrate the audio from your HDMI source into 3.5 mm audio applications using MU6MMRCA, MU3MMRCA or MUFMRCA (sold separately).
The compact extractor features a small footprint that blends discreetly into your hardware setup, for a uniform look.
Versatile audio connections
The HDMI audio extractor features multiple audio output types, including mini-phone 3.5 mm, RCA x 2, and SPDIF, enabling compatibility with audio equipment. -
Reliable performance
This device is designed to operate effectively within a temperature range of 0 °C to 45 °C, ensuring performance in environments. -
Easy installation
The package comes with mounting screws and brackets, facilitating installation and setup for both home and professional use.
- StarTech.com HDMI Audio Extractor - 4K 60Hz - HDMI Audio De-embedder - HDR - Toslink Optical Audio - Dual RCA Audio - HDMI Audio (HD202A) - HDMI audio signal extractor
- Product Type
- Package Content
- Power adapter, HDMI audio signal extractor, mounting screws, mounting brackets
- Product Material
- Aluminium
- 8 cm x 9 cm x 2.2 cm
- 320 g
- Black
- 2-year warranty
- Product Type
- Package Content
- Product Material
- Aluminium
- 8 cm
- 9 cm
- 2.2 cm
- 320 g
- Black
- Connections
- HDMI input - 19 pin HDMI Type A , HDMI output - 19 pin HDMI Type A , Audio line-out - mini-phone 3.5mm , SPDIF output - TOS Link , Component video/audio input - RCA x 2
- Power Source
- AC power adapter
- 2-year warranty
- Shipping Weight
- 400 g
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.00 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.48 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.78 |
StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male | In Stock | £4.91 |
StarTech.com 15 ft Thin Toslink Digital Optical SPDIF Audio Cable | In Stock | £5.37 |
StarTech.com HDMI Audio Extractor - 1080p | In Stock | £12.79 |
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £11.32 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £15.37 |
StarTech.com 3m 10ft Premium HDMI 2.0 Cable | In Stock | £19.66 |
