StarTech.com 4K HDMI 4-Port Video Splitter
Price Drop!
Clearance
Last Few Remaining
Price Drop
Quicklinx: B7JFWS00 Mfr#: ST124HD4K
More than 50 in stock
£60.43 ex VAT
£72.51 inc VAT
Split an HDMI audio/video source on four separate HDMI displays simultaneously, with support for resolutions up to 4K. The ST124HD4K 4-port 4K HDMI splitter lets you share an HDMI display or projector with four HDMI-enabled audio / video source devices, such as computers, Blu-ray players and cable TV set-top boxes.
With support for Ultra HD (4K) the HDMI splitter ensures astonishing picture quality, four times the resolution of high-definition 1080p at 30 Hz. The 4K splitter is also backward compatible with previous HDMI revisions, supporting 1080p / 720p HDMI video resolution devices. Even if you don't require 4K video today, the ST124HD4K ensures you'll be ready to take advantage of tomorrow's display technology.
Constructed of solid aluminum, the HDMI splitter casing is heavy enough to prevent the unit from shifting or sliding around when you move the attached HDMI cables. Plus, the small footpring allows for seamless integration into any digital signage application.
StarTech.com 4K HDMI 4-Port Video Splitter - 1x4 HDMI Splitter - 4K 30Hz - video/audio switch - 4 ports
Video/audio switch - 4 ports
Subtype
HDMI
Ports
4 x HDMI
AC 120/230 V
8.5 cm x 13.9 cm x 1.4 cm
285 g
Enclosure Type
Desktop
Subtype
HDMI
Ports
4 x HDMI
Max Resolution
3840 x 2160
4 x HDMI output , 1 x HDMI input
External power adapter
AC 120/230 V
FCC, RoHS
8.5 cm
13.9 cm
1.4 cm
285 g
70 °C
5 - 90%
Min Storage Temperature
-10 °C
Max Storage Temperature
80 °C
B7JF StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.14
B7JF StarTech.com 4K HDMI 2-Port Video Splitter – 1x2 HDMI Splitter – Powered by USB or Power Adapter In Stock £48.86
B7JF StarTech.com 4K HDMI 2-Port Video Splitter – 1x2 HDMI Splitter w/ Solid Aluminum Housing – 4K 30Hz In Stock £44.10
B7JF StarTech.com 4K HDMI 4-Port Video Splitter In Stock £60.43
Price Range Ex VAT: 50 - 100
