Split an HDMI audio/video source on four separate HDMI displays simultaneously, with support for resolutions up to 4K. The ST124HD4K 4-port 4K HDMI splitter lets you share an HDMI display or projector with four HDMI-enabled audio / video source devices, such as computers, Blu-ray players and cable TV set-top boxes.
With support for Ultra HD (4K) the HDMI splitter ensures astonishing picture quality, four times the resolution of high-definition 1080p at 30 Hz. The 4K splitter is also backward compatible with previous HDMI revisions, supporting 1080p / 720p HDMI video resolution devices. Even if you don't require 4K video today, the ST124HD4K ensures you'll be ready to take advantage of tomorrow's display technology.
Constructed of solid aluminum, the HDMI splitter casing is heavy enough to prevent the unit from shifting or sliding around when you move the attached HDMI cables. Plus, the small footpring allows for seamless integration into any digital signage application.
- StarTech.com 4K HDMI Splitter - 4k 30Hz - 4 Port - Aluminum - Backward Compatible - HDMI Multi Port - HDMI Hub (ST124HD4K) - video/audio switch - 4 ports
- Video/audio switch - 4 ports
- Subtype
- HDMI
- Ports
- 4 x HDMI
- Power
- AC 120/230 V
- 8.5 cm x 13.9 cm x 1.4 cm
- 285 g
- Black
- 2-year warranty
- Designed For
- P/N: ST121HDBT20L, ST121HDBT20S, ST121HDBTE, SVA5H2NEUA
- Enclosure Type
- Desktop
- Subtype
- HDMI
- Ports
- 4 x HDMI
- Max Resolution
- 3840 x 2160
- 4 x HDMI output , 1 x HDMI input
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- FCC, RoHS
- 8.5 cm
- 13.9 cm
- 1.4 cm
- 285 g
- Limited warranty - 2 years
- 0 °C
- 70 °C
- 5 - 90%
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 80 °C
- Designed For
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.37 |
StarTech.com 4 Port High Speed HDMI Video Splitter w/ Audio | In Stock | £103.47 |
StarTech.com 2 Port High Speed HDMI Video Splitter and Signal Amplifier | In Stock | £84.10 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £8.38 |
StarTech.com HDMI Over Single Cat 5e / 6 Extender with Power Over Cable - 230 ft (70m) | In Stock | £215.74 |
StarTech.com 4K HDMI 2-Port Video Splitter – 1x2 HDMI Splitter – Powered by USB or Power Adapter | In Stock | £54.03 |
StarTech.com 4K HDMI 4-Port Video Splitter | In Stock | £62.23 |
StarTech.com 8-Port 4K 60Hz HDMI Splitter | In Stock | £134.78 |
StarTech.com HDMI Splitter - 4 Port - 4K 60Hz | In Stock | £54.71 |
