StarTech.com 4K HDMI 4-Port Video Splitter
PRICE DROP!
Clearance
Last Few Remaining
Price Drop
Quicklinx: B7JFWS00 Mfr#: ST124HD4K
£56.90 ex VAT
£68.28 inc VAT
Split an HDMI audio/video source on four separate HDMI displays simultaneously, with support for resolutions up to 4K. The ST124HD4K 4-port 4K HDMI splitter lets you share an HDMI display or projector with four HDMI-enabled audio / video source devices, such as computers, Blu-ray players and cable TV set-top boxes.
With support for Ultra HD (4K) the HDMI splitter ensures astonishing picture quality, four times the resolution of high-definition 1080p at 30 Hz. The 4K splitter is also backward compatible with previous HDMI revisions, supporting 1080p / 720p HDMI video resolution devices. Even if you don't require 4K video today, the ST124HD4K ensures you'll be ready to take advantage of tomorrow's display technology.
Constructed of solid aluminum, the HDMI splitter casing is heavy enough to prevent the unit from shifting or sliding around when you move the attached HDMI cables. Plus, the small footpring allows for seamless integration into any digital signage application.
  • Robust video support
    Supports a maximum resolution of 3840 x 2160 for stunning video quality across multiple displays.
  • Versatile connectivity
    Includes four HDMI outputs, enabling multiple devices to share a single source effortlessly.
  • Durable design
    Constructed from aluminum, the splitter is built to withstand daily use while maintaining a modern look.
  • Temperature resistant
    Operates efficiently in a wide range of temperatures from 0°C to 70°C, suitable for various environments.
  • Safety compliant
    Meets FCC and RoHS standards, ensuring a safe and environmentally friendly product.
StarTech.com 4K HDMI Splitter - 4k 30Hz - 4 Port - Aluminum - Backward Compatible - HDMI Multi Port - HDMI Hub (ST124HD4K) - video/audio switch - 4 ports
Video/audio switch - 4 ports
Subtype
HDMI
Ports
4 x HDMI
AC 120/230 V
8.5 cm x 13.9 cm x 1.4 cm
285 g
P/N: ST121HDBT20L, ST121HDBT20S, ST121HDBTE, SVA5H2NEUA
Enclosure Type
Desktop
Subtype
HDMI
Ports
4 x HDMI
Max Resolution
3840 x 2160
4 x HDMI output , 1 x HDMI input
External power adapter
AC 120/230 V
FCC, RoHS
8.5 cm
13.9 cm
1.4 cm
285 g
70 °C
5 - 90%
Min Storage Temperature
-10 °C
Max Storage Temperature
80 °C
B7JF StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
B7JF StarTech.com 4 Port High Speed HDMI Video Splitter w/ Audio In Stock £85.12
B7JF StarTech.com 2 Port High Speed HDMI Video Splitter and Signal Amplifier In Stock £64.86
B7JF StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.74
B7JF StarTech.com HDMI Over Single Cat 5e / 6 Extender with Power Over Cable - 230 ft (70m) In Stock £174.69
B7JF StarTech.com 4K HDMI 2-Port Video Splitter – 1x2 HDMI Splitter – Powered by USB or Power Adapter In Stock £46.48
B7JF StarTech.com DC Power Adapter - 5V, 2A In Stock £9.21
B7JF StarTech.com 8-Port 4K 60Hz HDMI Splitter In Stock £123.91
B7JF StarTech.com HDMI Splitter - 4 Port - 4K 60Hz In Stock £51.02
