StarTech.com 48-Port 2U Cat6 Patch Panel
Quicklinx: JG6CWS00 Mfr#: CPANEL48
Hurry, only 1 left in stock!
£75.50 ex VAT
£90.60 inc VAT
Organize up to 48 Cat6 cables with a rackmount patch panel built for high-capacity network setups
This 48-Port 2U Cat6 Patch Panel provides a reliable way to route and manage Ethernet connections in rack-mounted network setups. It's designed for high-density environments like data centers and server rooms, where structured cable management and long-term performance are critical.
Structured Connectivity
The 2U network patch panel features clearly numbered RJ45 ports and color-coded 110 punch-down blocks that support both T568A and T568B wiring. The intuitive layout helps simplify installation, keeps cable paths organized, and facilitates accurate fault isolation when troubleshooting.
Durable Construction
A robust steel housing with a black powder-coated finish protects the rackmount patch panel in demanding environments. Gold-plated contacts ensure lasting signal integrity, and 110 punch-down terminals facilitate secure, fixed cable connections for stable Ethernet performance.
