The ATX2PW450BR 450 watt 80 Plus Bronze power supply offers an energy efficient replacement or upgrade for powering your desktop PC. Operating at an 82% to 85% efficiency between 20% and 100% load, 80 Plus Bronze power supplies deliver a significant improvement over standard-efficiency power supplies that helps reduce energy consumption and cost of operation.
This versatile power supply is equipped to support AMD or Intel CPU-based servers and workstations with a combined 20/24-pin motherboard connection, and an 8-pin EPS connector.
- StarTech.com 450 Watt ATX12V 2.3 80 Plus Bronze Computer Power Supply w/ Active PFC - power supply - 450 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.3/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS Bronze
- Input Voltage
- AC 115/230 V
- Output Voltage
- +3.3, ±5, ±12 V
- Power Capacity
- 450 Watt
- Output Current
- +12V1 - 37 A , +12V2 - 37 A , +12V3 - 37 A , +12V4 - 37 A , +3.3V - 20 A , +5V - 20 A , -12V - 0.5 A , +5VSB - 2.5 A , -5V - 37 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 4 pin ATX12V connector , 1 x 8 pin PCI Express power , 4 x 15 pin Serial ATA power , 3 x 4 PIN internal power
- Cooling System
- 120 mm fan
- Black
- 15 cm x 14 cm x 8.6 cm
- 2-year warranty
- PSU Form Factor
- ATX
- Black
- Input Voltage
- AC 115/230 V
- Input Voltage Range
- AC 110 - 240 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, ±5, ±12 V
- Power Capacity
- 450 Watt
- Output Current
- 80 PLUS Bronze
- Cooling System
- 120 mm fan
- Over current protection, over voltage protection, overpower protection, short-circuit protection, non-modular
- UL, FCC, RoHS
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90%
- 15 cm
- 14 cm
- 8.6 cm
