StarTech.com 45 ft Coax High Resolution Monitor VGA Cable - HD15 M/M
Quicklinx: 7P02WS00 Mfr#: MXT101MMHQ45
This 45-foot High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male-to-male coaxial VGA cable eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 45 ft. (13.7 m) VGA to VGA Cable - HD15 Male to HD15 Male - Coaxial High Resolution - High Quality - VGA Monitor Cable (MXT101MMHQ45) - VGA cable - 13.7 m
VGA cable
Triple shielded twisted pair coaxial
Ferrite bead
Length
13.7 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
NEC-CMG
P/N: CDP2VGA, CDP2VGAFC, DVI2VGAE, DVIVGAMF, DVIVGAMFBK, HD2VGAE2, HD2VGAMICRO
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Ferrite bead
Length
13.7 m
Connector
NEC-CMG
7P02 StarTech.com Slimline Adapter HDDB15 F/F In Stock £5.33
7P02 StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F In Stock £6.85
