StarTech.com 42U Server Rack Cabinet
Quicklinx: HFP3WS00 Mfr#: RK4236BKB
Depth (mm): 100cm
Width (mm): 60cm
Hurry, only 2 left in stock!
£1,283.14 ex VAT
£1,539.76 inc VAT
This 42U server rack cabinet provides secure storage space for storing EIA-310 compliant 19" rack-mount devices such as Dell, HP and IBM servers, as well as telecommunication and A/V equipment. The server rack provides an economical yet robust solution, with a total load capacity of 907 kg (2000 lb.).
This network rack comes assembled, providing hassle-free deployment.
With adjustable mounting rails, you can easily change the rail depth from 6 to 36 in. (152.4 mm - 914.4 mm) to support full-depth equipment. The extra depth also supports additional cable and power management behind your equipment.
Both the top and bottom panels have removable cable-access covers which provide easy access for cable management. The rack also features a grounding wire, which can be used in the front or rear, enabling you to ground your equipment for added protection.
To help keep your rack-mounted equipment secure, this rack features a reversible front door allowing for different rack configurations. The front and rear doors are both lockable, and the mesh design increases airflow to provide passive cooling.
The rack also has easily removable and lockable side panels, which allow for quick access to your equipment while still keeping it secure.
The enclosure cabinet comes with both casters and leveling feet already installed, providing ease of mobility around your office, studio, or server room. Additionally, the width and height of the rack fit through standard doorways, providing the freedom to move your rack as needed.
StarTech.com 42U Server Rack Cabinet - 4-Post Adjustable Depth (5.9" to 36.4") IT Network Equipment Rack Enclosure with Casters - 2000lbs (RK4236BKB) - rack - 42U
Rack
Rack Type
Cabinet
Placing / Mounting
Floor-standing
Package Content
50 washers, 2 side panel keys, 2 door keys, 50 M6 screws, 50 M6 cage nuts, hex key
Rack Size
19"
Height (Rack Units)
42U
Product Material
Steel
60 cm x 100 cm x 192.2 cm
Key lock, adjustable depth, removable side panel, removable door, mesh front door, mesh rear door, casters, adjustable rails, reversible front door, 4 post
5-year warranty
Rack
Rack Type
Cabinet
Placing / Mounting
Floor-standing
Product Material
Steel
Package Content
Rack Size
19"
Height (Rack Units)
42U
60 cm
100 cm
192.2 cm
Weight Limit
907 kg
Limited warranty: - 5 years , Technical support: - lifetime
HFP3 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £96.93
HFP3 StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £84.93
HFP3 StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.34
HFP3 StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.51
HFP3 StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £31.10
HFP3 StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £477.22
HFP3 StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £335.92
HFP3 StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £7.49
HFP3 StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £11.75
HFP3 StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.45
HFP3 StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.56
HFP3 StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.09
HFP3 StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.23
HFP3 StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.89
HFP3 StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf In Stock £92.13
HFP3 StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £542.00
HFP3 StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £284.45
HFP3 StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £317.76
HFP3 StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £635.38
HFP3 StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £86.73
HFP3 StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets In Stock £101.34
HFP3 StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £63.29
HFP3 StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £77.90
HFP3 StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £33.04
HFP3 StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £73.91
HFP3 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £82.73
HFP3 StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £55.31
HFP3 StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £44.71
HFP3 StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £37.48
HFP3 StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £52.08
HFP3 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
HFP3 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.40
HFP3 StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.45
HFP3 StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £39.94
HFP3 StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg In Stock £162.10
HFP3 StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.00
HFP3 StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.96
HFP3 StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £23.35
HFP3 StarTech.com 1U Server Rack Panel In Stock £11.99
HFP3 StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £57.09
HFP3 StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.44
HFP3 StarTech.com 100 Pkg M5 Cage Nuts In Stock £26.80
HFP3 StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.46
HFP3 StarTech.com 100 Pkg M5 Cage Nuts In Stock £28.99
HFP3 StarTech.com 50 Pkg M5 Cage Nuts In Stock £15.59
HFP3 StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £54.01
HFP3 StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £29.06
HFP3 StarTech.com 50 Pkg M5 Mounting Screws In Stock £16.04
HFP3 StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.99
HFP3 StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.75
HFP3 StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.29
HFP3 StarTech.com 100 Pkg M6 Cage Nuts In Stock £28.49
HFP3 StarTech.com 19in Cable Management Panel In Stock £23.30
HFP3 StarTech.com M6 Mounting Screws 50Pack In Stock £16.78
Depth (mm): 100cm
Width (mm): 60cm
Price Range Ex VAT: £1000 - £1500
