StarTech.com 40-Pin IDE PATA to SATA Adapter Converter for HDD/SSD/ODD
Quicklinx: 9N9TWS00 Mfr#: IDE2SAT2
Connect your SATA Hard Drive or Blu-ray/DVD/CD-ROM Drive to an IDE motherboard. The IDE2SAT240-pin IDE to SATA adapter enables you to connect a SATA I/II/III drive to an available IDE/ATA 33/66/100/133 motherboard port - a cost-effective solution that allows you to add newer SATA drives, and keep your existing motherboard.
The IDE/SATA adapter offers a cost-effective solution for bridging the gap between a newer 2.5"/3.5"/5.25" SATA drive and older IDE motherboard port. The IDE2SAT2 also features ODD (Optical Disk Drive) support, allowing you to a add Blu-ray, DVD, or CD-ROM drives to an older IDE motherboard.
  • Efficient connectivity
    This adapter converter simplifies the process of connecting SATA storage devices to older 40-pin PATA interfaces, allowing for upgrades.
  • High data transfer rate
    A data transfer rate of 133 MBps ensures that data is accessed quickly, enhancing overall performance.
  • Broad compatibility
    Supports hard drives, CD drives, and DVD drives, providing versatility for various storage needs.
  • Standard compliance
    Complies with both FCC and RoHS standards, highlighting a commitment to quality and environmental responsibility.
  • Single device support
    Designed to connect one storage device at a time, making it ideal for straightforward setups.
StarTech.com IDE to SATA Hard Drive or Optical Drive Adapter Converter - 40-Pin PATA to 2.5" SATA HDD / SSD / ODD Converter (IDE2SAT2) - storage controller - SATA 1.5Gb/s - Ultra ATA/133
Storage controller
Bus Type
Ultra ATA/133
SATA 1.5Gb/s
Data Transfer Rate
133 MBps
Supported Devices
Hard drive, CD drive, DVD drive
Channel Qty
1
Max Storage Devices Qty
1
2 cm x 7.55 cm x 2.3 cm
15 g
Storage controller
Host Bus
Ultra ATA/133
Storage Controller
SATA 1.5Gb/s
Data Transfer Rate
133 MBps
Supported Devices
Channel Qty
1
1
1 x SATA 1.5Gb/s - SATA combo
1 - 40 PIN IDC
1 x power cable
FCC, RoHS
2 cm
7.55 cm
2.3 cm
15 g
9N9T StarTech.com LP4 to 2x LP4 Power Y Splitter Cable M/F In Stock £4.52
9N9T StarTech.com 3.5in Universal Hard Drive Mounting Bracket Adapter for 5.25in Bay In Stock £3.02
9N9T StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter In Stock £13.55
9N9T StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £15.57
