StarTech.com 40"/1m Neoprene Cable Management Sleeve
Quicklinx: G8L5WS00 Mfr#: WKSTNCMZP
Accessory Type: Cable Management
10 In Stock
£9.42 ex VAT
£11.30 inc VAT
Cable Management Sleeve Zipper Built-in Exit Holes 2-Year Warranty. Professionally organize and conceal your cables with this 39.4" (1m) Neoprene cable management sleeve, and neatly conceal your power, data, video, and networking cables. With 1.2" (30mm) inner diameter, this sleeve offers ample room to accommodate your everyday cable management needs.
Customizable Solution
This sleeve come with connector buckles on both the ends, allowing you to daisy-chain additional sleeves, which is ideal for longer cable runs and multi-monitor setup in your home-office, office, and boardroom.
For added convenience this sleeve also offers 11 evenly spaced built-in cable exit holes.
Sturdy Design
Made from durable Neoprene rubber with 0.12" (3mm) thickness, this sleeve is resistant to everyday wear & tear, foot traffic or damage by pets. Long lasting Nylon zippers and double-stitched connector buckles are designed for frequent use and are ideal for use in long cable runs.
Soft and flexible Neoprene also makes it easier to position and route the sleeve around sharp corners or bends.
Quick Hassle-free Installation
Smart zipper design with built-in exit holes for cables offers fast and easy installation. No need to disconnect cables and face work interruptions or down time in order to re-route cords through a traditional sleeve; Just wrap this Neoprene zipper sleeve around your cables and fasten the zipper. Add as many additional sleeves as you need to.
The WKSTNCMZP is backed by a StarTech.com 2-year warranty and free lifetime technical support.
  • Customizable solution
    This sleeve has built-in connector buckles allowing you to daisy-chain additional sleeves as required.
  • Durable and flexible sleeve
    Cable manager made from rugged Neoprene rubber prevents wear & tear due to extended use, foot traffic or damage by pets.
  • Quick and easy installation
    Just wrap the cable organizer sleeve around existing cords and fasten the zipper; fast & easy installation, no need to unplug connections, no work interruption or wasted time.
StarTech.com 40" (1m) Neoprene Cable Management Sleeve with Zipper & Buckle, 1.2" (3cm) Diameter, Computer/PC Power/Network/AV Cord Cover/Manager, Flexible Cable Organizer Wrap, Black - Cable Manager Sleeve (WKSTNCMZP) - cable management sleeve
Cable management sleeve
Product Material
Neoprene
3.05 cm 3.05 cm
Length
1 m
108 g
Nylon zipper
Product Material
Neoprene
3.05 cm
3.05 cm
Length
1 m
108 g
20 cm x 20 cm x 10 cm / 110 g
Inner Dimensions
3 cm x 3 cm
Nylon zipper
DOC, RoHS, WEEE, REACH
Limited warranty: - 2 years
