This 4-way privacy screen is designed to fit the iPhone 16 Pro Max. The security filter ensures optimal privacy in portrait or landscape orientations when viewed beyond 30° from the center, covering a total visible area of 60°. Security shield with high-gloss finish that helps retain color vibrancy and features a coating to protect the display against scratches and fingerprints. The included applicator frame ensures a quick, precise, and bubble-free installation directly onto the iPhone screen for a long-lasting fit. The tempered glass protector features a precise fit that does not interfere with sensors around the display, front camera, or earpiece. The blue light reduction privacy shield blocks 50% of the blue light emitted from the display (in the 390nm - 440nm wavelength range).
4-Way Privacy and Touch Support
The security filter ensures optimal privacy in portrait or landscape orientations when viewed beyond 30° from the center, covering a total visible area of 60°. It supports touchscreen input and gestures, preserving the interactive experience of an iPhone while maintaining the confidentiality of on-screen content. Security shield with high-gloss finish that helps retain color vibrancy and features a coating to protect the display against scratches and fingerprints -
Installation
The included applicator frame ensures a quick, precise, and bubble-free installation directly onto the iPhone screen for a long-lasting fit. The tempered glass protector features a precise fit that does not interfere with the sensors around the display, front camera, or earpiece. -
Blue Light Reduction
This Blue Light Reduction Privacy Shield reduces eye strain and improves visual comfort by blocking 50% of the blue light emitted from the display (in the 390nm - 440nm wavelength range).
- StarTech.com - screen protector for mobile phone - 4-way filter, 4-way 360, supports portrait/landscape orientation, touch-enabled - TAA Compliant
- Product Type
- Screen protector - glass - with privacy filter - 4-way
- Intended For
- Mobile phone
- Installation Type
- Adhesive
- Protection
- Blue light reduction
- Package Content
- Screen protector, applicator frame, cleaning kit, squeegee
- Product Material
- Tempered glass
- 19.14 cm 0.89 cm
- Length
- 8.19 cm
- 45 g
- Black
- TAA Compliant
- 2-year warranty
- Designed For
- Apple iPhone 16 Pro Max
- Product Type
- Privacy Protection
- 4-way
- Intended For
- Mobile phone
- Installation Type
- Adhesive
- Protection
- Package Content
- Product Material
- Tempered glass
- 19.14 cm
- 0.89 cm
- Length
- 8.19 cm
- 45 g
- Black
- TAA Compliant
- Limited warranty - 2 years
- Shipping Width
- 22.9 cm
- Shipping Depth
- 9.5 cm
- Shipping Height
- 1.7 cm
- Shipping Weight
- 72 g
- Designed For
