StarTech.com 4-Way Privacy Screen iPhone 16
Quicklinx: J7YNWS00 Mfr#: I16T1-PRIVACY-SCREEN
28 In Stock
£27.43 ex VAT
£32.91 inc VAT
This 4-way privacy screen is designed to fit the iPhone 16. The security filter ensures optimal privacy in portrait or landscape orientations when viewed beyond 30° from the center, covering a total visible area of 60°. Security shield with high-gloss finish that helps retain color vibrancy and features a coating to protect the display against scratches and fingerprints. The included applicator frame ensures a quick, precise, and bubble-free installation directly onto the iPhone screen for a long-lasting fit. The tempered glass protector features a precise fit that does not interfere with sensors around the display, front camera, or earpiece. The blue light reduction privacy shield blocks 50% of the blue light emitted from the display (in the 390nm - 440nm wavelength range).
  • 4-Way Privacy and Touch Support
    The security filter ensures optimal privacy in portrait or landscape orientations when viewed beyond 30° from the center, covering a total visible area of 60°. It supports touchscreen input and gestures, preserving the interactive experience of an iPhone while maintaining the confidentiality of on-screen content. Security shield with high-gloss finish that helps retain color vibrancy and features a coating to protect the display against scratches and fingerprints
  • Installation
    The included applicator frame ensures a quick, precise, and bubble-free installation directly onto the iPhone screen for a long-lasting fit. The tempered glass protector features a precise fit that does not interfere with the sensors around the display, front camera, or earpiece.
  • Blue Light Reduction
    This Blue Light Reduction Privacy Shield reduces eye strain and improves visual comfort by blocking 50% of the blue light emitted from the display (in the 390nm - 440nm wavelength range).
StarTech.com - screen protector for mobile phone - 4-way filter, 4-way 360, supports portrait/landscape orientation, touch-enabled - TAA Compliant
Screen protector - glass - with privacy filter - 4-way
Intended For
Mobile phone
Installation Type
Adhesive
Protection
Blue light protection, scratch protection, fingerprint protection
Package Content
Screen protector, applicator frame, cleaning kit, squeegee
Product Material
Tempered glass
7.69 cm 0.92 cm
Length
17.4 cm
39.5 g
TAA Compliant
Apple iPhone 16
Privacy Protection
4-way
Intended For
Mobile phone
Installation Type
Adhesive
Protection
Package Content
Product Material
Tempered glass
7.69 cm
0.92 cm
Length
17.4 cm
39.5 g
TAA Compliant
Shipping Width
22.9 cm
Shipping Depth
9.5 cm
Shipping Height
1.7 cm
Shipping Weight
73 g
Apple iPhone 16
