StarTech.com 4-Way Privacy Screen For 12.9in iPad Pro
Quicklinx: HM9FWS00 Mfr#: 129IP-PRIVACY-SCREEN
Device Type: iPad Pro
Type: Privacy Screen
Device Screen Size: 12.9
Colour: [N/A]
10 In Stock
£17.72 ex VAT
£21.26 inc VAT
This Privacy Screen for third-generation and newer 12.9 iPad Pro smoothly transitions from a clear view to an obscured screen beyond the intended viewing angle, significantly enhancing visual privacy in office or public environments. The anti-glare matte finish helps to reduce reflections in glare-prone environments and provides additional screen protection with a scratch and fingerprint-resistant coating.
  • 4-Way Privacy and Touch Support
    The security filter ensures optimal privacy in portrait or landscape orientations when viewed beyond 30° from the center, covering a total visible area of 60°. It supports touchscreen input and gestures, preserving the interactive experience of an iPad while maintaining the confidentiality of on-screen content.
  • Installation
    The screen protector is compatible with third-generation and newer 12.9 iPad Pro and features a precise fit that does not interfere with the display, camera, or speakers. The included installation kit and step-by-step instructions allow for a one-time application to the iPad screen.
  • Blue Light Reduction
    This Blue Light Reduction Privacy Shield reduces eye strain and improves visual comfort by blocking 40% - 51% of the blue light emitted from the display (in the 380nm - 480nm wavelength range). Symptoms of digital eye strain, such as headaches, dry eyes, and blurred vision, can be alleviated by using blue-light filtering privacy screens.
StarTech.com - screen protector for tablet - for portrait/landscape, touch-enabled, +/-30° view, blocks up to 51% blue light, matte
Screen protector - with privacy filter - 4-way
Intended For
Tablet
Screen Size Compatibility
12.9"
Protection
Scratch-resistant, anti-glare, blue light reduction, fingerprint-resistant
Package Content
Screen protector, cleaning wipes, squeegee, dust remover, 2 guide stickers, wiping cloth
Product Material
Plastic
21.2 cm 27.7 cm
Thickness
0.4 mm
58 g
Apple 12.9-inch iPad Pro (3rd generation, 4th generation, 5th generation, 6th generation)
Privacy Protection
4-way
Intended For
Tablet
12.9"
Protection
Package Content
Product Material
Plastic
21.2 cm
27.7 cm
58 g
Thickness
0.4 mm
Shipping Width
39 cm
Shipping Depth
0.6 cm
Shipping Height
24.5 cm
Shipping Weight
160 g
HM9F StarTech.com Desk Mountable Tablet Stand In Stock £96.07
HM9F StarTech.com Secure Tablet Stand w/Cable Lock, Locking 7.9-13"Tablet In Stock £79.14
Colour: [N/A]
