This 4-Port USB 3.2 Gen 1 (5Gbps) Hub adds four USB Type-A ports to a computer, with the added benefit of each port having an individual on/off switch. The USB hub is self-powered with an included power adapter. It connects to a USB-A, or USB-C port on a laptop or desktop computer.
                Four On/Off Port SwitchesThe four ports on the USB Hub feature a power switch to turn off the computers data/power connection to the attached device when it's not being used. This means you can turn off individual USB ports to reduce power consumption, without having to physically disconnect the device or cable. Also, this feature can ensure privacy by turning off cameras or external data storage devices that contain sensitive data, when they're not in use.
                Power and Charge USB DevicesThe USB hub is self-powered, with an included 36W power adapter. This enables all four ports on this USB hub to support BC 1.2, providing 1.5A (7.5W) of power simultaneously (30W total), making it ideal to charge battery powered USB devices like Smartphones, and Tablets, while also providing a data connection. The USB hub will provide power with or without a host computer connected, with support for both CDP (Charging Downstream Port) & DCP (Dedicated Charging Port) applications.
                Add Four USB Ports, to Connect USB DevicesThe 4-port USB 3.2 Gen 1 (5Gbps) Hub expands a computer's USB connectivity, adding four USB-A ports from a single USB-A or USB-C port. The USB hub is backward compatible with older USB 2.0 (480Mbps) devices, ensuring support for a wide range of modern and legacy USB devices such as external storage devices (thumb drives, HDDs/SSDs), HD Cameras, mice, keyboards, webcams, and USB headsets. USB 3.2 Gen 1 (5Gbps) is also known as USB 3.2 Gen 1 (5Gbps), and USB 3.0 (5Gbps).
                Hassle-Free, Plug-and-Play InstallationThe 4-Port USB Hub is OS independent supporting all operating systems including Windows, macOS, Chrome OS, iPad OS and Android, and installs automatically when connected to a computer. To ensure wide compatibility with USB host devices, individual 3.3 ft. (1 m) USB-A, and USB-C host cables are included. This product is backed for 2-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com 4-Port Self-Powered USB-C Hub with Individual On/Off Switches, USB 3.0 5Gbps Expansion Hub w/Power Supply, Desktop/Laptop USB-C to USB-A Hub, 4x BC 1.2 (1.5A), USB Type C Hub - USB-C/A Host Cables (5G4AIBS-USB-HUB-EU) - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x USB 3.2 Gen 1
- Self-powered mode, 4 on/off switches, aluminium housing, fast charging support, CDP, DCP
- USB 1.1, USB 2.0, USB 3.0, USB 3.2 Gen 1, Battery Charging 1.2
- Power
- AC 110-240 V
- 11.4 cm x 5.9 cm x 2.1 cm
- 128 g
- System Requirements
- Apple MacOS, Microsoft Windows, Android, Google Chrome OS, Apple iPadOS
- Localisation
- United Kingdom, Europe
- 2-year warranty
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- 4 x USB 3.2 Gen 1
- Processor
- X VIA VL817
- Status Indicators
- Connection status
- 4 x USB 3.2 Gen 1 Type A Battery Charging 1.2 , 1 x USB 3.2 Gen 1 Type B host
- Power Device
- External power adapter
- Power Provided
- DC 12 V - 3 A
- Voltage Required
- AC 110-240 V
- 36 Watt
- Cables Included
- 1 x USB-A to USB-B cable - 1 m , 1 x USB-C to USB-B cable - 1 m
- MTBF
- 50,000 hours
- Plug and Play, UASP (USB Attached SCSI Protocol)
- Localisation
- OS Required
- 11.4 cm
- 5.9 cm
- 2.1 cm
- 128 g
- Shipping Width
- 22.5 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 7 cm
- Shipping Weight
- 700 g
- Limited warranty - 2 years , Technical support - assistance - lifetime
- 0 °C
- 40 °C
- 10 - 90% RH (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
|  | StarTech.com 1m USB 3 Cable Right Angle BK | In Stock | £7.04 |
|  | StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £6.43 |
|  | StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.94 |
|  | StarTech.com 6in USB 3.0 Extension Cable | In Stock | £5.27 |
|  | StarTech.com 7-pt USB Hub with On/Off Switches | In Stock | £62.05 |
