StarTech.com 4-pt USB Hub with On/Off Switches
Quicklinx: GYR6WS00 Mfr#: 5G4AIBS-USB-HUB-EU
Type: USB Hub
Interface: USB
Speed: 5Gbps
Ports: 4
Form Factor: External
£43.41 ex VAT
£52.09 inc VAT
This 4-Port USB 3.2 Gen 1 (5Gbps) Hub adds four USB Type-A ports to a computer, with the added benefit of each port having an individual on/off switch. The USB hub is self-powered with an included power adapter. It connects to a USB-A, or USB-C port on a laptop or desktop computer.
  • Four On/Off Port Switches
    The four ports on the USB Hub feature a power switch to turn off the computers data/power connection to the attached device when it's not being used. This means you can turn off individual USB ports to reduce power consumption, without having to physically disconnect the device or cable. Also, this feature can ensure privacy by turning off cameras or external data storage devices that contain sensitive data, when they're not in use.
  • Power and Charge USB Devices
    The USB hub is self-powered, with an included 36W power adapter. This enables all four ports on this USB hub to support BC 1.2, providing 1.5A (7.5W) of power simultaneously (30W total), making it ideal to charge battery powered USB devices like Smartphones, and Tablets, while also providing a data connection. The USB hub will provide power with or without a host computer connected, with support for both CDP (Charging Downstream Port) & DCP (Dedicated Charging Port) applications.
  • Add Four USB Ports, to Connect USB Devices
    The 4-port USB 3.2 Gen 1 (5Gbps) Hub expands a computer's USB connectivity, adding four USB-A ports from a single USB-A or USB-C port. The USB hub is backward compatible with older USB 2.0 (480Mbps) devices, ensuring support for a wide range of modern and legacy USB devices such as external storage devices (thumb drives, HDDs/SSDs), HD Cameras, mice, keyboards, webcams, and USB headsets. USB 3.2 Gen 1 (5Gbps) is also known as USB 3.2 Gen 1 (5Gbps), and USB 3.0 (5Gbps).
  • Hassle-Free, Plug-and-Play Installation
    The 4-Port USB Hub is OS independent supporting all operating systems including Windows, macOS, Chrome OS, iPad OS and Android, and installs automatically when connected to a computer. To ensure wide compatibility with USB host devices, individual 3.3 ft. (1 m) USB-A, and USB-C host cables are included. This product is backed for 2-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 4-Port Self-Powered USB-C Hub with Individual On/Off Switches, USB 3.0 5Gbps Expansion Hub w/Power Supply, Desktop/Laptop USB-C to USB-A Hub, 4x BC 1.2 (1.5A), USB Type C Hub - USB-C/A Host Cables (5G4AIBS-USB-HUB-EU) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB 3.2 Gen 1
Self-powered mode, 4 on/off switches, aluminium housing, fast charging support, CDP, DCP
USB 1.1, USB 2.0, USB 3.0, USB 3.2 Gen 1, Battery Charging 1.2
AC 110-240 V
11.4 cm x 5.9 cm x 2.1 cm
128 g
Apple MacOS, Microsoft Windows, Android, Google Chrome OS, Apple iPadOS
United Kingdom, Europe
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB 3.2 Gen 1
X VIA VL817
Status Indicators
Connection status
4 x USB 3.2 Gen 1 Type A Battery Charging 1.2 , 1 x USB 3.2 Gen 1 Type B host
External power adapter
Power Provided
DC 12 V - 3 A
AC 110-240 V
36 Watt
1 x USB-A to USB-B cable - 1 m , 1 x USB-C to USB-B cable - 1 m
MTBF
50,000 hours
Plug and Play, UASP (USB Attached SCSI Protocol)
11.4 cm
5.9 cm
2.1 cm
128 g
Shipping Width
22.5 cm
Shipping Depth
17 cm
Shipping Height
7 cm
Shipping Weight
700 g
Limited warranty - 2 years , Technical support - assistance - lifetime
10 - 90% RH (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
GYR6 StarTech.com 1m USB 3 Cable Right Angle BK In Stock £7.04
GYR6 StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £6.51
GYR6 StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.94
GYR6 StarTech.com 6in USB 3.0 Extension Cable In Stock £5.45
GYR6 StarTech.com 7-pt USB Hub with On/Off Switches In Stock £62.05
Type: USB Hub
Interface: USB
Speed: 5Gbps
Ports: 4
