StarTech.com 4 Port VGA Over CAT5 Video Extender - 450ft (150m)
Quicklinx: 7ZDLWS00 Mfr#: ST1214T
Type: Video Extender
£109.08 ex VAT
£130.89 inc VAT
The ST1214T 4 port VGA video extender over Cat 5 allows a single VGA source to be broadcast to up to four remote displays at distances of up to 500 feet (150 meters). Designed for use with the ST121 VGA video over Cat 5 extension series of devices, the ST1214T is one of many options designed to help you create a custom VGA distribution and extension solution for many applications including digital signage and video conferencing.
Consisting of the transmitter unit only, this product requires a single ST121R receiver unit per remote display that you are connecting. If you are looking for an eight port transmitter solution, StarTech.com offers the ST1218T 8 port VGA extender unit.
For even more versatility, the ST121EXT VGA over Cat 5 repeater can be used to increase the total VGA extension distance by an additional 500 feet (150 meters), allowing the original VGA signal to be broadcast a total distance of 1000 feet (300 meters) from transmitter to receiver. Similarly, up to three repeater units can be used between the transmitter and receiver units allowing a monitor to be connected at each repeater station, while further extending the total distance between the transmitter and receiver units.
StarTech.com VGA Over CAT5 Video Extender - VGA Extender - 450ft (150m) - 4-Port (ST1214T) - video extender
Video extender
Ports Qty
4
External
Max Transfer Distance
150 m
P/N: ST121EXT, ST121R, SVA12M2NEUA, SVA12M5NA
Video extender
External
Ports Qty
4
Wired
Max Resolution
1024 x 768
150 m
Status Indicators
Power, active
1 x VGA (input) - HD-15 male , 1 x VGA (output) - HD-15 female , 4 x display / video - output - RJ-45 female
FCC
External power adapter
7ZDL StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.80
7ZDL StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £5.80
7ZDL StarTech.com 15 ft Coax VGA Monitor Extension Cable - HD15 M/F In Stock £11.68
7ZDL StarTech.com 8 Port VGA Video Extender over Cat 5 In Stock £182.14
7ZDL StarTech.com 4 Port VGA Over CAT5 Video Extender - 450ft (150m) In Stock £109.08
Price Range Ex VAT: 100 - 150
