StarTech.com 4-Port USBC Hub - 10Gbps
Quicklinx: FLXSWS00 Mfr#: HB31C3A1CPD3
Type: USB
Ports: 4
Data Transfer Rate: [N/A]
Managed: No
POE: PoE
10 In Stock
£47.00 ex VAT
£56.40 inc VAT
Expand the connectivity of your USB-C laptop with this new generation USB-C Gen 2 hub offering 10Gbps supporting greater bandwidth to connected devices and faster data transfer speeds. This bus-powered 4-Port USB-C hub plugs into your laptop's USB Type-C or Thunderbolt 3 port, adding one USB-C port and three USB-A ports, while allowing charging of your laptop.
The USB-C hub can support Power Delivery (3.0) pass through, when using a USB-C power adapter, to charge your laptop, with 15W reserved to power the hub itself.
This compact, lightweight USB-Type-C hub is a convenient and portable addition to your laptop accessories. The USB-C cable is built-in, and hub is bus-powered, so it draws its power directly from your computer's USB-C port, with no external power required. That means fewer cables to carry with you when you travel. The hub can draw up to 15 Watts of power from the connected host and operating multiple bus powered devices at one time with the total available power dependent on the connected host.
The extended length attached cable of 9.8" (25 cm) provides more flexibility for longer reach connection requirements and plug-and-play installation.
With ports for both USB-C and USB-A peripherals, this hub is backwards compatible supporting both legacy and new USB devices. You can connect flash drives, video capture devices and external hard drives, with fast data transfer speeds of up to 10Gbps. This 4-port USB Type-C hub enhances your productivity, giving you the connections, you need while you work.
  • Versatile connectivity
    Equipped with 3 USB-A and 1 USB-C ports, this hub allows for simultaneous connection of multiple devices, making it an ideal accessory for both personal and professional use.
  • High-speed data transfer
    Capable of reaching speeds up to 10 Gbps, this hub ensures that large files are transferred swiftly, enhancing productivity and efficiency.
  • Easy setup
    With its Plug-and-Play design, this USB hub requires no additional drivers or software, allowing immediate use upon connection.
  • Environmentally friendly
    Compliant with various standards such as RoHS and WEEE, this product is designed with environmental responsibility in mind.
  • Durability and reliability
    Able to operate between 0 °C and 50 °C and withstand storage temperatures as low as -20 °C, this hub is built to perform across a range of environments.
StarTech.com 4 Port USB C Hub (10Gbps) to 3x USB-A & 1x USB-C, 100W Power Delivery Passthrough Charging, Compact/Portable USB 3.1 Gen 2/USB 3.2 Gen 2 Type C Laptop Adapter, Works w/ TB3 - Windows/macOS/Linux - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
1 x USB-C + 3 x USB 3.1
USB powered
USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2, Power Delivery 3.0, USB 3.2 Gen 2
31 cm x 20.7 cm x 3.8 cm
196 g
Black, space grey
P/N: PEXUSB321C
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
USB powered
X Realtek Semiconductor RTS5423
1 x USB 3.1 Gen 2 Type C , 3 x USB 3.1 Gen 2 Type A
Black, space grey
1 x USB-C cable - 25 cm
Plug and Play, FCC, RoHS, WEEE, REACH, UASP (USB Attached SCSI Protocol)
31 cm
20.7 cm
3.8 cm
196 g
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
P/N: PEXUSB321C
FLXS StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.01
FLXS StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £10.24
FLXS StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.21
FLXS StarTech.com USB 3.0 USB-C to USB-A Adapter In Stock £8.24
FLXS StarTech.com 1m USB 3.1 C Cable w/ PD (5A) In Stock £26.27
FLXS StarTech.com 0.5m USB 3.1 C - Micro B Cable In Stock £9.59
FLXS StarTech.com 0.5m USB C Cable - USB 3.1 In Stock £12.76
FLXS StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £14.97
FLXS StarTech.com 4 -Port USB-C Hub 10 Gbps - 3x USB-A & 1x USB-C In Stock £32.28
FLXS StarTech.com 3-Port USB-C Hub with LAN Port - 10Gbps In Stock £55.62
FLXS StarTech.com 3-Port USB-C Hub with SD Card Reader - 10Gbps In Stock £47.36
FLXS StarTech.com 3 Port USB C 3.1 Gen 2 Hub with Ethernet Adapter In Stock £63.26
FLXS StarTech.com 4 -Port USB-C™ Hub 10 Gbps - 2x USB-A & 2x USB-C In Stock £43.29
FLXS StarTech.com 4 Port USB C Hub - 3 USB-A/1 USB-C (5Gbps USB 3.0) - 11.2" Cable In Stock £43.12
FLXS StarTech.com 4 Port USB C Hub 5Gbps - 4x USB-A - Bus Powered USB 3.0 Type-C Hub - 11in Cable In Stock £25.28
FLXS StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub In Stock £112.74
FLXS StarTech.com 4 Port USB C Hub 10Gbps In Stock £117.38
FLXS StarTech.com 4-Port USB-C Hub, 100W PD In Stock £38.06
FLXS StarTech.com 4-Port USB-C Hub, 5Gbps, PD In Stock £40.43
FLXS StarTech.com Portable 4pt USB-C Hub, 10Gbps In Stock £31.91
FLXS StarTech.com Industrial USB 2.0 Hub In Stock £38.22
Type: USB
Ports: 4
Managed: No
POE: PoE
