Expand the connectivity of your USB-C laptop with this new generation USB-C Gen 2 hub offering 10Gbps supporting greater bandwidth to connected devices and faster data transfer speeds. This bus-powered 4-Port USB-C hub plugs into your laptop's USB Type-C or Thunderbolt 3 port, adding one USB-C port and three USB-A ports, while allowing charging of your laptop.
The USB-C hub can support Power Delivery (3.0) pass through, when using a USB-C power adapter, to charge your laptop, with 15W reserved to power the hub itself.
This compact, lightweight USB-Type-C hub is a convenient and portable addition to your laptop accessories. The USB-C cable is built-in, and hub is bus-powered, so it draws its power directly from your computer's USB-C port, with no external power required. That means fewer cables to carry with you when you travel. The hub can draw up to 15 Watts of power from the connected host and operating multiple bus powered devices at one time with the total available power dependent on the connected host.
The extended length attached cable of 9.8" (25 cm) provides more flexibility for longer reach connection requirements and plug-and-play installation.
With ports for both USB-C and USB-A peripherals, this hub is backwards compatible supporting both legacy and new USB devices. You can connect flash drives, video capture devices and external hard drives, with fast data transfer speeds of up to 10Gbps. This 4-port USB Type-C hub enhances your productivity, giving you the connections, you need while you work.
Versatile connectivity
Equipped with 3 USB-A and 1 USB-C ports, this hub allows for simultaneous connection of multiple devices, making it an ideal accessory for both personal and professional use. -
High-speed data transfer
Capable of reaching speeds up to 10 Gbps, this hub ensures that large files are transferred swiftly, enhancing productivity and efficiency. -
Easy setup
With its Plug-and-Play design, this USB hub requires no additional drivers or software, allowing immediate use upon connection. -
Environmentally friendly
Compliant with various standards such as RoHS and WEEE, this product is designed with environmental responsibility in mind. -
Durability and reliability
Able to operate between 0 °C and 50 °C and withstand storage temperatures as low as -20 °C, this hub is built to perform across a range of environments.
- StarTech.com 4 Port USB C Hub (10Gbps) to 3x USB-A & 1x USB-C, 100W Power Delivery Passthrough Charging, Compact/Portable USB 3.1 Gen 2/USB 3.2 Gen 2 Type C Laptop Adapter, Works w/ TB3 - Windows/macOS/Linux - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 1 x USB-C + 3 x USB 3.1
- USB powered
- USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2, Power Delivery 3.0, USB 3.2 Gen 2
- 31 cm x 20.7 cm x 3.8 cm
- 196 g
- Black, space grey
- 2-year warranty
- Designed For
- P/N: PEXUSB321C
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- USB powered
- Processor
- X Realtek Semiconductor RTS5423
- 1 x USB 3.1 Gen 2 Type C , 3 x USB 3.1 Gen 2 Type A
- Black, space grey
- Cables Included
- 1 x USB-C cable - 25 cm
- Plug and Play, FCC, RoHS, WEEE, REACH, UASP (USB Attached SCSI Protocol)
- 31 cm
- 20.7 cm
- 3.8 cm
- 196 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 0 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Designed For
- P/N: PEXUSB321C
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £8.90 |
StarTech.com 1m USB 3.1 C to Micro-B Cable | In Stock | £10.07 |
StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M | In Stock | £13.20 |
StarTech.com USB 3.0 USB-C to USB-A Adapter | In Stock | £8.11 |
StarTech.com 1m USB 3.1 C Cable w/ PD (5A) | In Stock | £25.63 |
StarTech.com 0.5m USB 3.1 C - Micro B Cable | In Stock | £9.36 |
StarTech.com 0.5m USB C Cable - USB 3.1 | In Stock | £12.46 |
StarTech.com 1m 3ft USB 3.1 C to B Cable | In Stock | £15.26 |
StarTech.com 4 -Port USB-C Hub 10 Gbps - 3x USB-A & 1x USB-C | In Stock | £31.99 |
StarTech.com 3-Port USB-C Hub with LAN Port - 10Gbps | In Stock | £54.28 |
StarTech.com 3-Port USB-C Hub with SD Card Reader - 10Gbps | In Stock | £46.20 |
StarTech.com 4 Port USB C Hub - 3 USB-A/1 USB-C (5Gbps USB 3.0) - 11.2" Cable | In Stock | £42.74 |
StarTech.com 4 Port USB C Hub 5Gbps - 4x USB-A - Bus Powered USB 3.0 Type-C Hub - 11in Cable | In Stock | £25.05 |
StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub | In Stock | £109.99 |
StarTech.com 4 Port USB C Hub 10Gbps | In Stock | £114.53 |
StarTech.com 4-Port USB-C Hub, 100W PD | In Stock | £37.13 |
StarTech.com 4-Port USB-C Hub, 5Gbps, PD | In Stock | £39.46 |
StarTech.com Portable 4pt USB-C Hub, 10Gbps | In Stock | £31.13 |
StarTech.com Industrial USB 2.0 Hub | In Stock | £42.46 |
