Control 4 VGA, USB-equipped PCs with a single peripheral set, with USB Dynamic Device Mapping to avoid switching lag-time.
The SV431USBDDM 4-Port USB VGA KVM Switch lets you control 4 VGA, USB-equipped PCs using a single peripheral set at high-definition VGA resolutions up to 1920x1440.
The included KVM cables provide a ready-out-of-the-box solution, while USB Dynamic Device Mapping (DDM) and Display Data Channel (DDC) features work to significantly reduce switching lag-time and improve overall compatibility with your connected display and input devices, saving you time and money.
For the next level in KVM performance, this VGA KVM switch integrates multi-core dedicated processing per channel and innovative, USB DDM technology that enables you to quickly switch between connected computers with next-to-zero delay. DDM maintains a constant communication channel between your USB peripherals and connected systems, avoiding the time necessary for your systems to re-recognize the devices when switching.
In addition to faster switching, the KVM offers All-time Display Data Channel (Full DDC) technology to maintain proper display detection among connected systems, a simple one-touch button for hot-key selection and an integrated 2-port USB hub allowing you to share additional peripherals
- StarTech.com 4 Port USB VGA KVM Switch with DDM Fast Switching and Cables - KVM / USB switch - 4 ports
- Subtype
- KVM
- Ports
- 4 x KVM / USB
- KVM Users Qty
- 1 local user
- Power
- AC 120/230 V
- 13.1 cm x 27.5 cm x 4.4 cm
- 1.1 kg
- Black
- Localisation
- North America, United Kingdom, Europe
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 4 x KVM / USB
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1920 x 1440
- 4 x VGA HD-15 , 2 x keyboard (USB) / mouse (USB) Type A , 1 x VGA HD-15 , 4 x USB Type B , 1 x USB Type A , 1 x RJ-45
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- FCC, RoHS
- Localisation
- 13.1 cm
- 27.5 cm
- 4.4 cm
- 1.1 kg
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 0 - 80% (non-condensing)
- Min Storage Temperature
- -30 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
StarTech.com 6 ft 2-in-1 USB KVM Cable | In Stock | £7.92 |
StarTech.com 4 Port Professional VGA USB KVM Switch with Hub | In Stock | £85.20 |
StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub | In Stock | £128.51 |
