StarTech.com 4 Port USB VGA IP KVM Switch with Virtual Media
Quicklinx: 76QDWS00 Mfr#: SV441DUSBI
The SV441DUSBI 4 Port IP KVM Switch revolutionizes remote server management by combining the industry-leading third generation Server Remote Control technology with a proven Enterprise class digital KVM switch.
The switch empowers you to securely manage up to four computers remotely from almost anywhere, using your LAN or the Internet. Unlike software solutions that require installation and work through your server's operating system, this IP KVM Switch gives you BIOS level control and full interaction with your system's boot process, and includes several security features (SSH tunneling, SSL Encryption, RADIUS authentication and a configurable firewall) that help to ensure that your network stays secure.
A versatile Server Remote Control solution, the switch features two additional USB ports that can be used to connect a broad range of peripherals (USB drive, USB CD ROM, USB flash drive) that can be shared among connected computers, allowing for disk emulation and file transfers, including complete remote application and operating system installations.
The IP KVM switch also provides control/interaction with virtually any device that uses an RS-232 serial terminal interface (routers, switches, environmental controls, alarm systems etc.), using the Serial Remote Interface Module; similarly, the SV441DUSBI can be used with the Remote Power Module to power computers and equipment on an off using an interactive menu.
The SV441DUSBI IP KVM Switch is the perfect solution for any organization that demands secure, flexible local and remote administration of its critical systems, and features a standardized 1U rack-mountable metal chassis that allows easy installation in your existing rack or cabinet solution.
StarTech.com 4 Port USB VGA IP KVM Switch with Virtual Media - 4 Port Remote KVM over IP (SV441DUSBI) - KVM switch - 4 ports
Enclosure Type
1U
Subtype
KVM
Ports
4 x KVM port(s)
KVM Users Qty
1 local user, 1 IP user
On-Screen Display, DHCP support
43.2 cm x 18.6 cm
2.5 kg
3-year warranty
P/N: RACKCOND17HD, RKCONS1701, SVA12M2NEUA, SVA12M5NA
Enclosure Type
Desktop 1U
Subtype
KVM
Ports
4 x KVM port(s)
KVM Local Users Qty
1 local user
KVM IP Users Qty
1 IP user
Keyboard / Mouse Interface
USB
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS
Max Resolution
1600 x 1200 @ 85 Hz
Status Indicators
Port status
4 x KVM HD-15 , 1 x RS-232 - 9 pin D-Sub (DB-9) management , 1 x management , 2 x USB Type A , 1 x VGA HD-15 , 2 x USB Type A , 1 x KVM RJ-45
External power adapter
1 x serial cable , 4 x keyboard / mouse / video cable
FCC, RoHS
43.2 cm
18.6 cm
2.5 kg
Limited warranty - 3 years
76QD StarTech.com 4 Port Professional VGA USB KVM Switch with Hub In Stock £83.88
76QD StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable In Stock £8.84
76QD StarTech.com DC Power Adapter - 12V, 2A In Stock £11.76
76QD StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
