StarTech.com 4-Port USB Hub 5Gbps, Portable
Quicklinx: H13KWS00 Mfr#: 5G4AB-USB-A-HUB
Type: USB Hub
Interface: USB-A
Speed: 5Gbps
Ports: 4
Form Factor: External
£25.83 ex VAT
£30.99 inc VAT
This USB Hub adds four USB-A 3.2 Gen 1 (5Gbps) ports to a USB-A enabled desktop or laptop computer. The USB Hub connects to a USB-A port on a computer, using the built-in 1ft. (30cm) host cable. The USB hub is backward compatible with USB 2.0 (480Mbps) devices, ensuring support for a wide range of modern and legacy USB peripherals (e.g., thumb drives, external HDDs/SSDs, HD cameras, mice, keyboards, webcams, and audio headsets).The USB hub is compact in size, facilitating portability when travelling.
  • Bus-Powered with Optional Auxiliary Power
    The USB hub can operate with bus power alone, but features a Micro USB power input that can be connected to a USB power adapter (not included), providing up to 4.5W (5V/0.9A) of power in addition to the 4.5W of bus power from the USB host. This flexibility is ideal for applications where additional power may be required, such as connecting a high-powered USB device, like an external SSD, while using the other ports to connect lower powered devices. The downstream ports are each capable of providing up to 4.5W of power to the connected peripherals. For added protection to this USB hub and the connected host device, the USB hub features Overcurrent Protection (OCP). OCP prevents faulty USB peripherals from drawing more power than is safely allocated.
  • Plug and Play
    This device is OS independent, supporting all operating systems, including Windows, macOS, ChromeOS, and Android. The Hub is automatically detected, configured, and installed upon connection to a host computer, such as Apple MacBook, Lenovo X1 Carbon, and Dell XPS. The extra long built-in 1ft. (30 cm) USB-A host cable enables quick and convenient setup and reduces connector strain on 2-in-1 devices, such as the Surface Pro 7 and laptops on riser stands.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that is compatible with a wide variety of IT connectivity accessories. The applicable software for this product is the USB Event Monitoring Utility. Use this utility to track and log any connected USB devices.
StarTech.com 4-Port USB Hub, USB 3.0 5Gbps, Bus Powered, USB-A to 4x USB-A Hub with Optional Auxiliary Power Input, Portable Desktop/Laptop USB Hub with 1ft (30cm) Attached Cable - USB Expansion Hub (5G4AB-USB-A-HUB) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB 3.2 Gen 1 + 1 x micro-USB
Performance
Data transfer rate: 5 Gbps
USB powered, plastic housing, USB overcurrent detection and prevention
USB 3.2 Gen 1, USB 2.0, USB 1.1
5.4 cm x 42 cm x 1.6 cm
82 g
Space grey
Microsoft Windows, Apple MacOS, Linux, Apple iPadOS, Google Chrome OS, Android
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
Performance
X VIA VL817
4 x USB 3.2 Gen 1 Type A , 1 x micro-USB input Type B
Space grey
1 x USB 3.2 Gen 1 cable - 30 cm
UASP (USB Attached SCSI Protocol), RoHS, WEEE, RCM, Plug and Play
5.4 cm
42 cm
1.6 cm
82 g
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
133 g
Limited warranty - 2 years , Technical support - assistance - lifetime
70 °C
0 - 85% RH (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
80 °C
H13K StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable In Stock £8.04
H13K StarTech.com USB 3.0 Dual Hard Drive Docking Station with UASP for 2.5/3.5in SSD / HDD – SATA 6Gbps In Stock £57.36
H13K StarTech.com USB 3.0 to 4-Bay SATA 6Gbps Hard Drive Docking Station w/ UASP & Dual Fans In Stock £76.10
H13K StarTech.com Dual-Bay SATA HDD/SSD Dock In Stock £51.20
H13K StarTech.com 3-Port USB Hub w/ GbE Adapter In Stock £34.41
H13K StarTech.com 3-Port USB-C Hub w/ Ethernet In Stock £30.87
H13K StarTech.com 4-Port USB-C Hub, 5Gbps In Stock £28.92
Type: USB Hub
Interface: USB-A
Speed: 5Gbps
Ports: 4
