StarTech.com 4 Port USB DisplayPort KVM Switch with Audio
Quicklinx: 6PG6WS00 Mfr#: SV431DPUA
Type: KVM / audio / USB switch
Connectivity: KVM
Ports: 4
£253.13 ex VAT
£303.75 inc VAT
This 4-Port USB DisplayPort KVM Switch combines the next generation of digital display interface standards with seamless KVM control of connected PC or Mac computers.
Delivering ideal multi-computer control for demanding high-resolution multimedia applications, or computer environments requiring true high definition capability, this robust KVM switch supports DisplayPort connections with a native resolution of 2560 x 1600 (at 60 Hz, 30 bpp), as well as 7.1 HD digital audio (when connected to supporting displays and sources).
In addition to offering 7.1 HD digital audio via the DisplayPort connection this four port KVM provides 3.5mm stereo analog audio and microphone switching between the four connected hosts.
Suitable for applications that require high quality static imaging, such as medical/health care applications (MRI, X-ray diagnostics etc.), the KVM switch supports a maximum resolution of 3840 x 2400 at a reduced refresh rate.
Adding cost-effective performance to cutting-edge multimedia capability, this versatile KVM switch features three Plug-and-Play USB console ports, including two dedicated peripheral (mouse and keyboard) ports and four USB 2.0 hub ports - enabling users to share a USB mouse and keyboard, and two USB 2.0 peripheral between the four connected computers.
A simple, yet comprehensive control solution, the 4-port KVM switch features both front-panel push-button and convenient hotkey switching and offers a small form factor design with connection ports situated on the rear panel, allowing you to eliminate workspace disruptions.
The SV431DPUA DisplayPort KVM switch is guaranteeing dependable, long-lasting performance.
StarTech.com 4 Port DisplayPort KVM Switch w/ Audio - USB, Keyboard, Video, Mouse, Computer Switch Box for 2560x1600 DP Monitor (SV431DPUA) - KVM / audio / USB switch - 4 ports
Subtype
KVM
Ports
4 x KVM / audio / USB
KVM Users Qty
1 local user
Built-in 2-port USB 2.0 hub
22.1 cm x 13.1 cm x 4.4 cm
1.1 kg
Microsoft Windows 7, Microsoft Windows Vista
3-year warranty
P/N: DP4N1USB6, IM12D1500P, SV431RACK, SVA12M2NEUA, SVA12M5NA
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2560 x 1600 @ 60 Hz
Status Indicators
Port status, power
4 x DisplayPort , 4 x USB 2.0 Type B , 4 x microphone input mini-jack , 4 x audio output mini-jack , 1 x DisplayPort , 1 x microphone input mini-jack , 1 x audio output mini-jack , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A
External power adapter
Rack Mounting Kit
Optional
Plug and Play, DDC-2B, FCC, RoHS
22.1 cm
13.1 cm
4.4 cm
1.1 kg
Limited warranty - 3 years
0 - 80%
6PG6 StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.27
6PG6 StarTech.com 4 Port USB DisplayPort KVM Switch with Audio In Stock £253.13
6PG6 StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F In Stock £9.68
6PG6 StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.06
6PG6 StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio In Stock £191.45
6PG6 StarTech.com DisplayPort USB KVM Switch In Stock £287.60
6PG6 StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) In Stock £25.42
6PG6 StarTech.com 6ft 4-in-1 USB DisplayPort KVM Switch Cable with Audio & Microphone In Stock £17.35
6PG6 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.06
6PG6 StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.99
6PG6 StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £6.03
6PG6 StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.26
6PG6 StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.79
6PG6 StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £15.63
6PG6 StarTech.com 2-port Dual VGA KVM Switch In Stock £67.05
6PG6 StarTech.com 4-port Dual VGA KVM Switch In Stock £176.26
6PG6 StarTech.com 4-Port DisplayPort KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable In Stock £393.59
6PG6 StarTech.com 2 Port Dual DP KVM Switch - 4K In Stock £259.12
6PG6 StarTech.com DC Power Adapter - 12V, 2A In Stock £12.61
6PG6 StarTech.com DC Power Adapter - 12V, 5A In Stock £41.02
6PG6 StarTech.com 4PT Dual DP KVM Switch 4K60 In Stock £599.68
6PG6 StarTech.com 2 Pt DisplayPort KVM In Stock £330.09
6PG6 StarTech.com 2 Port HDMI KVM Switch with Built-In Cables USB 4K 60Hz In Stock £84.89
6PG6 StarTech.com 2 Port USB 4K60Hz DisplayPort KVM Switch with Built-In Cable In Stock £95.65
6PG6 StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £12.46
Connectivity: KVM
Ports: 4
