This 4-Port USB DisplayPort KVM Switch combines the next generation of digital display interface standards with seamless KVM control of connected PC or Mac computers.
Delivering ideal multi-computer control for demanding high-resolution multimedia applications, or computer environments requiring true high definition capability, this robust KVM switch supports DisplayPort connections with a native resolution of 2560 x 1600 (at 60 Hz, 30 bpp), as well as 7.1 HD digital audio (when connected to supporting displays and sources).
In addition to offering 7.1 HD digital audio via the DisplayPort connection this four port KVM provides 3.5mm stereo analog audio and microphone switching between the four connected hosts.
Suitable for applications that require high quality static imaging, such as medical/health care applications (MRI, X-ray diagnostics etc.), the KVM switch supports a maximum resolution of 3840 x 2400 at a reduced refresh rate.
Adding cost-effective performance to cutting-edge multimedia capability, this versatile KVM switch features three Plug-and-Play USB console ports, including two dedicated peripheral (mouse and keyboard) ports and four USB 2.0 hub ports - enabling users to share a USB mouse and keyboard, and two USB 2.0 peripheral between the four connected computers.
A simple, yet comprehensive control solution, the 4-port KVM switch features both front-panel push-button and convenient hotkey switching and offers a small form factor design with connection ports situated on the rear panel, allowing you to eliminate workspace disruptions.
The SV431DPUA DisplayPort KVM switch is guaranteeing dependable, long-lasting performance.
Efficient connectivity
Equipped with four ports, this KVM switch enables easy connection to multiple computers, allowing for enhanced productivity and usability in any workspace. -
High video resolution
Supports a maximum video resolution of 2560 x 1600 at 60 Hz, delivering sharp and detailed images suitable for various applications. -
User-friendly operation
The Plug-and-Play design ensures a quick and hassle-free installation process, making it accessible for all users regardless of technical expertise. -
Versatile usage
Designed to operate in a wide range of environmental conditions, this KVM switch functions effectively in temperatures between 0°C and 40°C and humidity levels of 0-80%. -
Compact design
The desktop form factor allows for efficient use of desk space, making it suitable for home and office environments.
- StarTech.com 4 Port DisplayPort KVM Switch w/ Audio - USB, Keyboard, Video, Mouse, Computer Switch Box for 2560x1600 DP Monitor (SV431DPUA) - KVM / audio / USB switch - 4 ports
- Subtype
- KVM
- Ports
- 4 x KVM / audio / USB
- KVM Users Qty
- 1 local user
- Built-in 2-port USB 2.0 hub
- 22.1 cm x 13.1 cm x 4.4 cm
- 1.1 kg
- Black
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista
- 3-year warranty
- Designed For
- P/N: DP4N1USB6, IM12D1500P, SV431RACK, SVA12M2NEUA, SVA12M5NA
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 2560 x 1600 @ 60 Hz
- Status Indicators
- Port status, power
- 4 x DisplayPort , 4 x USB 2.0 Type B , 4 x microphone input mini-jack , 4 x audio output mini-jack , 1 x DisplayPort , 1 x microphone input mini-jack , 1 x audio output mini-jack , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A
- Power Device
- External power adapter
- Black
- Rack Mounting Kit
- Optional
- Plug and Play, DDC-2B, FCC, RoHS
- OS Required
- 22.1 cm
- 13.1 cm
- 4.4 cm
- 1.1 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 80%
- Designed For
StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.00 |
StarTech.com 4 Port USB DisplayPort KVM Switch with Audio | In Stock | £240.14 |
StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F | In Stock | £8.15 |
StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.50 |
StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio | In Stock | £189.49 |
StarTech.com DisplayPort USB KVM Switch | In Stock | £287.60 |
StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) | In Stock | £22.12 |
StarTech.com 6ft 4-in-1 USB DisplayPort KVM Switch Cable with Audio & Microphone | In Stock | £17.35 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £13.35 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.00 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.48 |
StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.06 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.78 |
StarTech.com 12V DC 1.5A Universal Power Adapter | In Stock | £15.66 |
StarTech.com 2-port Dual VGA KVM Switch | In Stock | £67.05 |
StarTech.com 4-Port DisplayPort KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable | In Stock | £342.46 |
StarTech.com 2 Port Dual DP KVM Switch - 4K | In Stock | £245.82 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £11.72 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.02 |
StarTech.com 4PT Dual DP KVM Switch 4K60 | In Stock | £568.94 |
StarTech.com 2 Pt DisplayPort KVM | In Stock | £287.20 |
StarTech.com 2 Port HDMI KVM Switch with Built-In Cables USB 4K 60Hz | In Stock | £83.26 |
StarTech.com 2 Port USB 4K60Hz DisplayPort KVM Switch with Built-In Cable | In Stock | £91.46 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £11.54 |
