Turn a USB Type-C port on your laptop into four USB Type-A ports (5Gbps), plus power and charge your laptop. This compact USB 3.0 hub lets you add four USB-A ports to your laptop, with support for USB power delivery. This means that you can power and charge your laptop through its USB-C port while simultaneously powering the hub.
With its integrated USB Type-C cable and small-footprint design, this versatile hub offers a perfectly portable solution for connecting devices that require traditional USB Type-A ports to your USB-C or Thunderbolt 3 equipped computer.
With its compact and rugged design, you can take this portable USB 3.0 hub anywhere you go. Because it's so compact, it's easy to tuck into your laptop bag and only takes up a small amount of desk space when you connect it to your workstation. For portable applications, having the integrated host (USB-C) cable means one less thing to remember to carry with you.
This USB-C 3.0 hub supports USB Power Delivery 2.0, so instead of carrying multiple cables and power adapters, you can use your laptop's USB-C power adapter to power both your laptop and the hub. By using just a single power adapter instead of two, you can eliminate clutter and hassle when you work.
This USB hub is multi-platform compatible, which means it will work with a wide range of USB-C laptops that use a USB-C power adapter. It also works with a range of operating systems such as Windows, macOS, Linux and Chrome OS . It installs automatically once you connect it to your laptop, so you can be up and running in seconds.
Efficient power delivery
With 60W Power Delivery Passthrough Charging, this USB C Hub ensures your devices stay charged and ready for use, whether you're presenting in a meeting or working on-the-go. -
High-speed connectivity
Experience data transfer rates of up to 5 Gbps with USB 3.0 technology, making file transfers faster and more efficient than ever. -
Versatile compatibility
Designed to work seamlessly with MacBook, Dell, and other compatible devices across Windows, macOS, and Linux platforms, this hub offers broad compatibility for a variety of setups. -
Plug-and-Play convenience
Thanks to its compliance with Plug-and-Play standards, this hub is ready to use right out of the box, requiring no additional software or drivers for installation.
- StarTech.com 4 Port USB C Hub with 4 USB Type-A Ports (USB 3.0 SuperSpeed 5Gbps), 60W Power Delivery Passthrough Charging, USB 3.1 Gen 1/USB 3.2 Gen 1 Laptop Hub Adapter, MacBook, Dell - Windows/macOS/Linux (HB30C4AFPD) - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x SuperSpeed USB 3.0
- USB powered, UASP
- USB 1.1, USB 2.0, USB 3.0, USB 3.1
- 4 cm x 9.3 cm x 1.1 cm
- 40.5 g
- Black
- System Requirements
- Apple MacOS, Linux, Microsoft Windows, Google Chrome OS
- 2-year warranty
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- USB powered, UASP
- Processor
- X VIA VL812
- 4 x USB 3.0 output Type A , 1 x USB 3.0 input Type C
- Black
- Cables Included
- 1 x SuperSpeed USB-C cable - 15 cm
- Plug and Play, FCC, RoHS, WEEE, USB Power Delivery 2.0
- OS Required
- 4 cm
- 9.3 cm
- 1.1 cm
- 40.5 g
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black | In Stock | £19.16 |
StarTech.com 4 Port Portable SuperSpeed USB 3.0 Hub with Built-in Cable | In Stock | £20.25 |
StarTech.com Rugged Hard Drive Enclosure | In Stock | £31.70 |
StarTech.com 4 Port USB 3.0 Hub - USB-C Hub | In Stock | £29.84 |
StarTech.com 1m USB 2.0 USB-C to USB-A Cable | In Stock | £8.44 |
StarTech.com 3m 10ft USB 3.0 A to A Cable | In Stock | £7.16 |
StarTech.com USB-C Multifunction Adapter | In Stock | £45.80 |
StarTech.com 6ft USB-C to A Cable - USB 2.0 | In Stock | £11.44 |
StarTech.com 4-Port USB-C Hub - USB 3.1 | In Stock | £33.92 |
StarTech.com 4-Port USB 3.0 Hub with On/Off | In Stock | £23.64 |
StarTech.com 4-Port USB-C Hub, 100W PD | In Stock | £37.13 |
StarTech.com 4-Port USB-C Hub, 5Gbps, PD | In Stock | £39.97 |
StarTech.com Portable 4pt USB-C Hub, 10Gbps | In Stock | £31.13 |
