StarTech.com 4-Port USB C Hub USB 3.1 Gen 2 (10Gbps) 3x USB-A & 1x USB-C
Quicklinx: FLXTWS00 Mfr#: HB31C3A1CS
Type: USB
Ports: 4
Data Transfer Rate: [N/A]
Managed: No
POE: PoE
£58.09 ex VAT
£69.70 inc VAT
Expand the connectivity of your USB-C laptop with this new generation USB-C 3.1 Gen 2 hub offering 10Gbps supporting greater bus bandwidth to connected devices and faster data transfer speeds. This self-powered 4-Port USB-C hub plugs into the USB Type-C or Thunderbolt 3 port on your device, adding one USB-C port and three USB-A ports, so you can quickly connect more USB devices.
This compact, lightweight USB-Type-C hub is a convenient and compact addition to your laptop setup. The hub is self-powered and includes a universal power adapter to provide better support of USB devices, such as external storage, that may draw more power.
The USB-C host cable is detached and with an extended length of 3.3' (1 m), it provides more flexibility for longer reach connection requirements and plug and play installation.
For added flexibility and security, the mini hub features mounting holes to work with StarTech.com dock mounts such as SSPMSVESA or SSPMSUDWM.
With ports for both USB-C and USB-A peripherals, this hub is backward compatible supporting both legacy and new USB devices. It features one always-on USB-A fast-charge port which supports two modes of operation: Data transfer and charging when the laptop is connected and on dedicated or hostless charging which provides a higher charging current, when the host is off, on standby, or disconnected.
You can connect video capture devices, portable flash drives, and external hard drives, with fast data transfer speeds of up to 10 Gbps. This 4 port USB Type-C hub enhances your productivity, giving you the connections you need while you work or travel.
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
  • Versatile connectivity
    This hub connects multiple devices simultaneously, allowing for enhanced productivity without sacrificing performance. The combination of USB-A and USB-C ports ensures compatibility with a wide range of peripherals.
  • Efficient power management
    With an external power adapter providing 24 W of operational power, this hub can support robust charging and data transfer, minimizing downtime and ensuring devices remain operational.
  • Robust compliance standards
    Adhering to multiple compliance standards such as FCC, RoHS, WEEE, and REACH, this product ensures safety and environmental responsibility, making it a reliable choice for various applications.
StarTech.com 4-Port USB C Hub - USB 3.1 Gen 2 (10Gbps) - 3x USB-A & 1x USB-C - Powered - Universal Power Adapter Included (HB31C3A1CS) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
1 x USB-C + 3 x USB 3.1
Metal housing, UASP, USB Pass-Through, Fast Charging Port, DCP
USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2, USB 3.2 Gen 2
AC 110/240 V 2 A
10 cm x 6 cm x 2.5 cm
470 g
Black, space grey
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 (32/64-bits), Microsoft Windows 7 / 8.1 / 10 (32/64 bits), Google Chrome OS 61, Apple MacOS X 10.10 - 10.13, Linux Kernel 4.x LTS, Ubuntu 14.04.x LTS, Ubuntu 16.04.x LTS, Android 8.x
Japan, New Zealand, North America, United Kingdom, Europe
P/N: PEXUSB321C
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
X Realtek Semiconductor RTS5423
1 x USB 3.1 Gen 2 Type C , 3 x USB 3.1 Gen 2 Type A
External power adapter
Power Provided
DC 12 V
AC 110/240 V
Electric Current Required
2 A
24 Watt
Black, space grey
1 x USB-C cable - 1 m
Plug and Play, FCC, RoHS, WEEE, REACH, UASP (USB Attached SCSI Protocol)
10 cm
6 cm
2.5 cm
470 g
Shipping Width
21.3 cm
Shipping Depth
14.9 cm
Shipping Height
5.1 cm
Shipping Weight
500 g
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
P/N: PEXUSB321C
FLXT StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £7.96
FLXT StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £10.07
FLXT StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.21
FLXT StarTech.com USB 3.0 USB-C to USB-A Adapter In Stock £8.05
FLXT StarTech.com 1m USB 3.1 C Cable w/ PD (5A) In Stock £25.63
FLXT StarTech.com 0.5m USB 3.1 C - Micro B Cable In Stock £9.09
FLXT StarTech.com 0.5m USB C Cable - USB 3.1 In Stock £12.46
FLXT StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £15.27
FLXT StarTech.com 4 -Port USB-C Hub 10 Gbps - 3x USB-A & 1x USB-C In Stock £31.99
FLXT StarTech.com 3-Port USB-C Hub with LAN Port - 10Gbps In Stock £53.70
FLXT StarTech.com 3-Port USB-C Hub with SD Card Reader - 10Gbps In Stock £46.20
FLXT StarTech.com Docking Station Mount - Wall Mount / Under-Desk Mounting Pla In Stock £9.28
FLXT StarTech.com Docking Station Mount - For StarTech.com Docks / Hubs - VESA In Stock £14.31
FLXT StarTech.com 4 -Port USB-C™ Hub 10 Gbps - 2x USB-A & 2x USB-C In Stock £41.59
FLXT StarTech.com 4 Port USB C Hub - 3 USB-A/1 USB-C (5Gbps USB 3.0) - 11.2" Cable In Stock £42.74
FLXT StarTech.com 4 Port USB C Hub 5Gbps - 4x USB-A - Bus Powered USB 3.0 Type-C Hub - 11in Cable In Stock £25.05
FLXT StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub In Stock £109.99
FLXT StarTech.com 4 Port USB C Hub 10Gbps In Stock £114.53
FLXT StarTech.com 4-Port USB-C Hub, 100W PD In Stock £37.13
FLXT StarTech.com Portable 4pt USB-C Hub, 10Gbps In Stock £31.13
FLXT StarTech.com Industrial USB 2.0 Hub In Stock £109.99
Type: USB
Ports: 4
Managed: No
POE: PoE
