StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub
Quicklinx: G8KZWS00 Mfr#: HB31C3A1CME
Type: USB
Ports: 4
Data Transfer Rate: [N/A]
Managed: No
POE: No
£115.92 ex VAT
£139.10 inc VAT
Industrial USB Hub - Metal Housing - Built-in Mounting Hardware - Screw Locking Ports
This 4-Port industrial USB hub enables you to connect four SuperSpeed USB 3.2 Gen 2 (10 Gbps) peripherals to your USB-A or USB-C computer. The hub features three USB-A and one USB-C peripheral ports, each with a screw-lock connector, and a metal industrial housing ideal for commercial environments.
Expands the Connectivity of Your Computer for Industrial Applications
With this USB-C hub you can connect three USB-A devices, and one USB-C device, to a single USB-C or USB-A port on your host device. The hub supports USB 3.2 Gen 2 (10 Gbps), and is backward compatible with USB 3.2 Gen 1 (5 Gbps) and USB 2.0 (480 Mbps).
Note: USB 3.2 Gen 2 (10 Gbps) is also known as USB 3.1 Gen 2 (10 Gbps), USB 3.2 Gen 1 (5 Gbps) is also know as USB 3.1 Gen 1 (5 Gbps), and USB 3.0 (5 Gbps).
Powers and Charges Your Connected Devices
The USB hub is self powered using either the included 36W (12V/3A) AC to DC power adapter, or the built-in terminal block connector that supports a 7-24V DC input. The hub shares up to 30W of power between connected devices and each port supports BC 1.2 providing 12W (2.4A) of power on all ports up to a 30W draw.
Ideal for Use in Industrial Environments
This USB hub has a rugged-metal enclosure with built-in mounting ears that enable you to mount it to any wall or surface. The hub features 15kV Air and 8kV Contact electrostatic discharge protection, with 350W surge protection. Each port on the Hub has a screw lock, avoiding the possibility of accidental cable disconnection and a 3.3 ft (1m) USB-C & USB-A host cables is included that features a locking screw.
Wide Device Compatibility
The USB hub is OS independent ensuring support on a wide range of platforms including Windows, macOS, Linux, iPadOS, Chrome OS and Android.
HB31C3A1CME is backed by a StarTech.com 2-year warranty and free lifetime 24/5 multi-lingual North American based technical support. StarTech.com has been the IT professionals' choice for over 30 years.
  • Expands the connectivity of your computer for industrial applications
  • Powers and charges your connected devices
  • Ideal for use in industrial environments
  • Wide device compatibility
StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB 3.2/3.1 Gen 2 Type-C Hub - 3A/1C - USB-C or USB-A Host - Mountable - ESD/Surge (HB31C3A1CME) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
1 x USB-C + 3 x USB 3.1
Surge protection, DCP, CDP, ESD Protector
USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2, USB 3.2 Gen 2
AC 110 - 230 V 1 A
5.96 cm x 15.2 cm x 2.35 cm
280 g
Apple MacOS, Linux, Microsoft Windows, Android, Google Chrome OS, Apple iPadOS
Japan, New Zealand, North America, United Kingdom, Europe
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
X VIA Labs VL822
1 x USB 3.1 Gen 2 Type C , 3 x USB 3.1 Gen 2 Type A
External power adapter
Power Provided
DC 12 V - 3 A
AC 110 - 230 V
Electric Current Required
1 A
36 Watt
1 x USB-C cable - 1 m , 1 x USB-C to USB-A cable - 1 m
FCC, RoHS, WEEE, RCM, UASP (USB Attached SCSI Protocol)
5.96 cm
15.2 cm
2.35 cm
280 g
Shipping Width
14.9 cm
Shipping Depth
29 cm
Shipping Height
7 cm
Shipping Weight
1.2 kg
70 °C
0 - 85%
Min Storage Temperature
-10 °C
Max Storage Temperature
55 °C
G8KZ StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £8.10
G8KZ StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £9.61
G8KZ StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £9.88
G8KZ StarTech.com 3ft Slim Micro USB 3.0 Cable In Stock £9.21
G8KZ StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £14.29
G8KZ StarTech.com 1m USB 3.1 C Cable w/ PD (5A) In Stock £25.63
G8KZ StarTech.com 4 -Port USB-C Hub 10 Gbps - 3x USB-A & 1x USB-C In Stock £33.73
G8KZ StarTech.com 3-Port USB-C Hub with LAN Port - 10Gbps In Stock £55.93
G8KZ StarTech.com 3-Port USB-C Hub with SD Card Reader - 10Gbps In Stock £48.70
G8KZ StarTech.com 1 m / 3.3 ft USB 2.0 to USB C Cable – Black In Stock £9.17
G8KZ StarTech.com 3 Port USB C 3.1 Gen 2 Hub with Ethernet Adapter In Stock £66.45
G8KZ StarTech.com 4 -Port USB-C™ Hub 10 Gbps - 2x USB-A & 2x USB-C In Stock £43.84
G8KZ StarTech.com 4 Port USB C Hub 10Gbps In Stock £120.71
G8KZ StarTech.com Industrial USB 2.0 Hub In Stock £115.92
G8KZ StarTech.com Industrial USB 3.0 Hub In Stock £306.30
G8KZ StarTech.com Industrial USB 5Gbps Hub In Stock £314.99
Type: USB
Ports: 4
Managed: No
POE: No
