StarTech.com 4-Port USB-C Hub, Compact
Quicklinx: JFZ1WS00 Mfr#: H5C4A-USB-HUB-2
More than 50 In Stock
£10.53 ex VAT
£12.63 inc VAT
Add four external USB 3.0 ports to your PC or laptop with a portable, PCR plastic hub
Add up to four USB 3.0 devices to your laptop or PC using a single USB-C port.
Stay Mobile with Compact, Bus-Powered Design
This lightweight 4-port hub is built for portability with a small footprint, 2ft (61cm) built-in cable, and no need for an external power adapter. Ideal for shared workspaces, home offices, and travel.
Easy Access to All Ports
With three ports on one side and one on the end, this hub makes it easy to plug and unplug devices when space is tight.
Broad Compatibility and Fast Setup
OS-independent and driver-free, this hub works with Windows, macOS, ChromeOS, and Linux. Just connect and start using.
Built for Sustainability, Designed for Performance
This hub features a housing made from 70% post-consumer recycled (PCR) plastic and a cable jacket composed of 35% PCR TPE (Thermoplastic Elastomer). The product also ships in FSC Mix packaging made from responsibly sourced materials. These materials help align your IT infrastructure with your organization's sustainability goals, without compromising on quality or durability.
Enterprise Management Tools
StarTech.com Connectivity Tools offer practical utilities to support device management and increase productivity in modern IT environments. The applicable software for this product is the USB Event Monitoring Utility which allows administrators to track and log connected USB devices.
Visit StarTech.com/Connectivity-Tools to download the Enterprise Management Tools.
