StarTech.com 4-Port USB-C Hub, 5Gbps, PD
Quicklinx: H13JWS00 Mfr#: 5G2A2CPDB-USB-C-HUB
Type: USB Hub
Interface: USB 3.1 Type C, USB 2.0
Speed: 5Gbps
Ports: 4
Form Factor: External
£40.43 ex VAT
£48.51 inc VAT
This USB-C Hub with 100W USB Power Delivery pass-through adds four USB 3.2 Gen 1 (5Gbps) ports (2x USB-A, 2x USB-C) to a USB-C enabled computer. Connect the USB hub to a USB-C port on a laptop, using the built-in 1ft (30cm) USB-C host cable. Charge a host laptop by connecting the host laptop's USB-C power supply to the USB Power Delivery (PD) 3.0 port. Backward compatible with USB 2.0 (480Mbps) devices ensures support for a wide range of modern and legacy USB peripherals (e.g., external storage devices - thumb drives, HDDs/SSDs, HD cameras, mice, keyboards, webcams, and audio headsets). The USB hub supports Wake on USB and is compact in size, facilitating portability when travelling.
  • USB Power Delivery Pass-Through
    This USB hub features USB Power Delivery 3.0 pass-through (up to 100W). This features enables the USB Type-C Hub to provide the option to use one of the downstream USB-C ports to connect a USB-C power source (up to 100W) to power and charge a laptop. PD 3.0 features Fast Role Swap (FRS) to prevent USB data disruption when switching power sources (USB-C power adapter to bus power). The USB Hub can operate with a USB-C power adapter connected or with bus-powered alone. It draws up to 15W of power from the USB-C host computer that's dynamically shared across the downstream ports. For added protection to this USB hub and the connected host device, the USB hub features Overcurrent Protection (OCP). OCP prevents faulty USB peripherals from drawing more power than is safely allocated.
  • Plug and Play
    This device is compatible with all major operating systems, including Windows, macOS, ChromeOS, iPadOS, and Android. The Hub is automatically detected, configured, and installed upon connection to a host computer. This ensures automatic installation and setting configuration with any USB-C laptop, including Thunderbolt 3, Thunderbolt 4 and USB4 computers such as Apple MacBook (Intel/M1/M2), Lenovo X1 Carbon and Dell XPS. The built-in extra-long 1 ft. (30 cm) USB-C host cable ensures easy setup and reduces connector strain on 2-in-1 devices such as the Surface Pro 7, iPad Pro, HP Elite X2 and laptops on riser stands.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that is compatible with a wide variety of IT connectivity accessories. The applicable software for this product is the USB Event Monitoring Utility. Use this utility to track and log any connected USB devices.
StarTech.com 4-Port USB-C Hub with 100W Power Delivery Pass-Through Charging, 2x USB-A + 2x USB-C, 5Gbps, USBC Hub w/ 1ft (30cm) Long Cable, Portable Laptop USB Type-C to USB-A/C Hub - USB 3.0 Expansion Hub (5G2A2CPDB-USB-C-HUB) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
2 x USB 3.2 Gen 1 + 2 x USB-C 3.2 Gen 1
Performance
Data transfer rate: 5 Gbps
USB powered, plastic housing, USB overcurrent detection and prevention, USB Power Delivery (up to 100 watt), USB Power Delivery 3.0
USB 1.1, USB 2.0, USB 3.0, USB 3.2 Gen 1, USB4
7.5 cm x 4.2 cm x 1.4 cm
41 g
Space grey
Android, Google Chrome OS, Apple iPadOS, Apple macOS 10.12 - 10.15, Apple macOS 10.11, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Linux Kernel 4.11.x or later (LTS versions only), Apple macOS 13.0
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
Performance
X Fresco Logic FL7102 / FL5001
2 x USB 3.2 Gen 1 Type A , 1 x USB 3.2 Gen 1 (power delivery) Type C pass-through , 1 x USB 3.2 Gen 1 Type C
15 Watt
Space grey
1 x USB-C cable - 30 cm
Plug and Play, RoHS, WEEE, UASP (USB Attached SCSI Protocol), Thunderbolt 3, Thunderbolt 4
7.5 cm
4.2 cm
1.4 cm
41 g
Shipping Width
14.2 cm
Shipping Depth
17.5 cm
Shipping Height
3 cm
Shipping Weight
94 g
Limited warranty - 2 years , Technical support - assistance - lifetime
45 °C
5 - 85% RH
Min Storage Temperature
-5 °C
Max Storage Temperature
70 °C
H13J StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable In Stock £8.33
H13J StarTech.com USB 3.0 Dual Hard Drive Docking Station with UASP for 2.5/3.5in SSD / HDD – SATA 6Gbps In Stock £58.80
H13J StarTech.com 1 Port USB-C™ Wall Charger with 60W of Power Delivery In Stock £33.26
Type: USB Hub
Interface: USB 2.0
Speed: 5Gbps
Ports: 4
