Expand the connectivity of your USB-C laptop with this new generation USB 3.1 Gen 2 hub offering 10Gbps supporting greater bus bandwidth to connected devices at faster data transfer speeds. This self-powered 4-Port USB-C hub plugs into the USB Type-C or Thunderbolt 3 port on your device, adding four USB-A ports, so you can quickly connect more USB devices.
This compact, lightweight USB-Type-C hub is a convenient and compact addition to your laptop setup. The hub is self-powered and includes a universal power adapter to provide better support of USB devices, such as external storage, that may draw more power.
The USB-C host cable is detached and with an extended length of 3.3' (1 m), it provides more flexibility for longer reach connection requirements and plug and play installation.
For added flexibility and security, the mini hub features mounting holes to work with StarTech.com dock mounts such as SSPMSVESA or SSPMSUDWM.
With support for USB-A peripherals, this multi port hub is backward compatible supporting both legacy and new USB devices. It features one always-on USB-A fast-charge port which supports two modes of operation: Data transfer and charging when the laptop is connected and on. Dedicated or hostless charging which provides a higher charging current, when the host is off, on standby, or disconnected.
You can connect video capture devices, portable flash drives, and external hard drives, with fast data transfer speeds of up to 10 Gbps. This 4 port USB Type-C hub enhances your productivity, giving you the connections you need while you work or travel.
- StarTech.com 4 Port USB C Hub with Power Adapter, USB 3.1/3.2 Gen 2 (10Gbps), USB Type C to 4x USB-A, Self Powered Desktop USB Hub with Fast Charging Port (BC 1.2) DCP, Desk Mountable - Windows/macOS/Linux (HB31C4AS) - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x USB 3.1 Gen 2
- Metal housing, Fast Charging Port, DCP
- USB 1.1, USB 2.0, USB 3.0, USB 3.2 Gen 2
- Power
- AC 110/240 V 2 A
- 10 cm x 6 cm x 2.5 cm
- Black, space grey
- Localisation
- Japan, New Zealand, North America, United Kingdom, Europe
- 2-year warranty
- Designed For
- P/N: PEXUSB321C
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- 4 x USB 3.1 Gen 2
- Processor
- X Realtek Semiconductor RTS5423
- Status Indicators
- Power
- 3 x USB 3.1 Gen 2 Type A , 1 x USB 3.1 Gen 2 Type A Fast-Charge , 1 x USB-C
- Power Device
- External power adapter
- Power Provided
- DC 12 V
- Voltage Required
- AC 110/240 V
- Electric Current Required
- 2 A
- 24 Watt
- Black, space grey
- Cables Included
- 1 x USB-C cable - 1 m
- Plug and Play, FCC, RoHS, WEEE, REACH, UASP (USB Attached SCSI Protocol)
- Localisation
- 10 cm
- 6 cm
- 2.5 cm
- Shipping Width
- 21.3 cm
- Shipping Depth
- 14.9 cm
- Shipping Height
- 5.1 cm
- Shipping Weight
- 500 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 0 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Designed For
- P/N: PEXUSB321C
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £10.55 |
StarTech.com 1m USB 3.1 C to Micro-B Cable | In Stock | £11.37 |
StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M | In Stock | £13.98 |
StarTech.com USB 3.0 USB-C to USB-A Adapter | In Stock | £8.21 |
StarTech.com 1m USB 3.1 C Cable w/ PD (5A) | In Stock | £26.96 |
StarTech.com 0.5m USB 3.1 C - Micro B Cable | In Stock | £10.41 |
StarTech.com 0.5m USB C Cable - USB 3.1 | In Stock | £15.19 |
StarTech.com 1m 3ft USB 3.1 C to B Cable | In Stock | £17.80 |
StarTech.com 4 -Port USB-C Hub 10 Gbps - 3x USB-A & 1x USB-C | In Stock | £44.33 |
StarTech.com 3 Port USB C 3.1 Gen 2 Hub with Ethernet Adapter | In Stock | £70.99 |
StarTech.com Docking Station Mount - Wall Mount / Under-Desk Mounting Pla | In Stock | £9.06 |
StarTech.com Docking Station Mount - For StarTech.com Docks / Hubs - VESA | In Stock | £14.35 |
StarTech.com 4 -Port USB-C™ Hub 10 Gbps - 2x USB-A & 2x USB-C | In Stock | £48.20 |
StarTech.com 4 Port USB C Hub - 3 USB-A/1 USB-C (5Gbps USB 3.0) - 11.2" Cable | In Stock | £47.36 |
StarTech.com 4 Port USB C Hub 5Gbps - 4x USB-A - Bus Powered USB 3.0 Type-C Hub - 11in Cable | In Stock | £27.93 |
StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub | In Stock | £129.88 |
StarTech.com 4 Port USB C Hub 10Gbps | In Stock | £135.21 |
StarTech.com 4-Port USB-C Hub, 100W PD | In Stock | £41.40 |
StarTech.com Portable 4pt USB-C Hub, 10Gbps | In Stock | £34.58 |
StarTech.com Industrial USB 2.0 Hub | In Stock | £121.00 |
StarTech.com 10-Port USB-C Hub Self-Powered | In Stock | £116.38 |
StarTech.com 7-Port USB-C Hub, Self-Powered | In Stock | £125.07 |
