StarTech.com 4-Port USB C Hub - USB 3.1 Gen 2 (10Gbps) - 4x USB-A Powered
Quicklinx: FLXVWS00 Mfr#: HB31C4AS
Type: Hub
Connectivity: USB
Ports: 4
£58.70 ex VAT
£70.44 inc VAT
Expand the connectivity of your USB-C laptop with this new generation USB 3.1 Gen 2 hub offering 10Gbps supporting greater bus bandwidth to connected devices at faster data transfer speeds. This self-powered 4-Port USB-C hub plugs into the USB Type-C or Thunderbolt 3 port on your device, adding four USB-A ports, so you can quickly connect more USB devices.
This compact, lightweight USB-Type-C hub is a convenient and compact addition to your laptop setup. The hub is self-powered and includes a universal power adapter to provide better support of USB devices, such as external storage, that may draw more power.
The USB-C host cable is detached and with an extended length of 3.3' (1 m), it provides more flexibility for longer reach connection requirements and plug and play installation.
For added flexibility and security, the mini hub features mounting holes to work with StarTech.com dock mounts such as SSPMSVESA or SSPMSUDWM.
With support for USB-A peripherals, this multi port hub is backward compatible supporting both legacy and new USB devices. It features one always-on USB-A fast-charge port which supports two modes of operation: Data transfer and charging when the laptop is connected and on. Dedicated or hostless charging which provides a higher charging current, when the host is off, on standby, or disconnected.
You can connect video capture devices, portable flash drives, and external hard drives, with fast data transfer speeds of up to 10 Gbps. This 4 port USB Type-C hub enhances your productivity, giving you the connections you need while you work or travel.
StarTech.com 4 Port USB C Hub with Power Adapter, USB 3.1/3.2 Gen 2 (10Gbps), USB Type C to 4x USB-A, Self Powered Desktop USB Hub with Fast Charging Port (BC 1.2) DCP, Desk Mountable - Windows/macOS/Linux (HB31C4AS) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB 3.1 Gen 2
Metal housing, Fast Charging Port, DCP
USB 1.1, USB 2.0, USB 3.0, USB 3.2 Gen 2
AC 110/240 V 2 A
10 cm x 6 cm x 2.5 cm
Black, space grey
Japan, New Zealand, North America, United Kingdom, Europe
P/N: PEXUSB321C
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB 3.1 Gen 2
X Realtek Semiconductor RTS5423
Status Indicators
3 x USB 3.1 Gen 2 Type A , 1 x USB 3.1 Gen 2 Type A Fast-Charge , 1 x USB-C
External power adapter
Power Provided
DC 12 V
AC 110/240 V
Electric Current Required
2 A
24 Watt
Black, space grey
1 x USB-C cable - 1 m
Plug and Play, FCC, RoHS, WEEE, REACH, UASP (USB Attached SCSI Protocol)
10 cm
6 cm
2.5 cm
Shipping Width
21.3 cm
Shipping Depth
14.9 cm
Shipping Height
5.1 cm
Shipping Weight
500 g
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
P/N: PEXUSB321C
FLXV StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.01
FLXV StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £10.24
FLXV StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.21
FLXV StarTech.com USB 3.0 USB-C to USB-A Adapter In Stock £8.24
FLXV StarTech.com 1m USB 3.1 C Cable w/ PD (5A) In Stock £25.86
FLXV StarTech.com 0.5m USB 3.1 C - Micro B Cable In Stock £9.59
FLXV StarTech.com 0.5m USB C Cable - USB 3.1 In Stock £12.76
FLXV StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £14.97
FLXV StarTech.com 4 -Port USB-C Hub 10 Gbps - 3x USB-A & 1x USB-C In Stock £32.28
FLXV StarTech.com 3-Port USB-C Hub with LAN Port - 10Gbps In Stock £55.62
FLXV StarTech.com 3-Port USB-C Hub with SD Card Reader - 10Gbps In Stock £47.36
FLXV StarTech.com 3 Port USB C 3.1 Gen 2 Hub with Ethernet Adapter In Stock £63.26
FLXV StarTech.com Docking Station Mount - Wall Mount / Under-Desk Mounting Pla In Stock £9.29
FLXV StarTech.com 4 -Port USB-C™ Hub 10 Gbps - 2x USB-A & 2x USB-C In Stock £43.29
FLXV StarTech.com 4 Port USB C Hub - 3 USB-A/1 USB-C (5Gbps USB 3.0) - 11.2" Cable In Stock £43.12
FLXV StarTech.com 4 Port USB C Hub 5Gbps - 4x USB-A - Bus Powered USB 3.0 Type-C Hub - 11in Cable In Stock £25.30
FLXV StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub In Stock £114.51
FLXV StarTech.com 4 Port USB C Hub 10Gbps In Stock £119.24
FLXV StarTech.com 4-Port USB-C Hub, 100W PD In Stock £38.06
FLXV StarTech.com Portable 4pt USB-C Hub, 10Gbps In Stock £31.91
FLXV StarTech.com Industrial USB 2.0 Hub In Stock £38.22
FLXV StarTech.com 10-Port USB-C Hub Self-Powered In Stock £112.29
FLXV StarTech.com 7-Port USB-C Hub, Self-Powered In Stock £104.01
Type: Hub
Connectivity: USB
Ports: 4
