StarTech.com 4-Port USB-C Hub - USB 3.1
Quicklinx: DPJDWS00 Mfr#: HB31C4AB
Type: USB Hub
Interface: SuperSpeed USB 3.0
Speed: 10Gbps
Ports: 4
Form Factor: External
£34.22 ex VAT
£41.06 inc VAT
USB Type C Hub , Bus-powered. Expand the connectivity of your USB-C laptop with this new-generation USB-C 10G hub. It plugs into your laptop's USB Type-C or Thunderbolt 3 port, adding four USB 3.1 Gen 2 Type-A ports, so you can quickly connect more USB devices. It's bus-powered, so there's no external power adapter required.
This four-port USB Type-C hub enhances your productivity, giving you the connections you need while you work. Connect the latest USB devices, like flash drives, capture devices and external hard drives, with fast data transfer speeds of up to 10Gbps, to save time when transferring large files.
The USB-C hub also lets you extend the life of your existing USB devices - it's backward compatible with previous versions of USB devices.
The compact, lightweight USB-Type-C hub is a convenient and portable addition to your laptop. It's bus-powered, so it draws its power directly from your computer's USB-C port, with no external power required. That means fewer cables to carry with you when you travel. It also has a built-in cable (9.8 in./25 cm) for convenient travel.
The USB 3.1 hub works with a wide range of operating systems, including macOS, Windows and Linux. It installs automatically when you connect it to your laptop or desktop, so you can be up and running quickly.
  • Compact design
    The hub features a compact form factor that makes it easy to integrate into any workspace setup, saving space while providing essential connectivity.
  • Versatile connectivity
    Equipped with four USB 3.0 Type-A ports, the hub offers enhanced connectivity options for multiple devices, enabling efficient data transfer and device management.
  • Reliable performance
    Built to comply with various USB standards, the hub ensures compatibility with a wide range of devices, supporting legacy and modern technology requirements.
  • Environmental adaptability
    This USB hub is designed to operate in various environmental conditions, withstanding temperatures from 0 °C up to 45 °C and humidity levels up to 80%.
  • USB-powered convenience
    The USB-powered feature of the hub removes the necessity for an additional power source, simplifying setup and maintaining a clean workspace.
StarTech.com 4-Port USB C Hub, USB-C to 4x USB-A Ports, SuperSpeed 10Gbps USB 3.1/USB 3.2 Gen 2 Type-C Hub, USB Bus Powered, Portable/Compact USB-C to USB Adapter Hub for Laptop, Aluminum - Windows/macOS/Linux (HB31C4AB) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
USB powered
USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2
1.58 cm x 4.3 cm x 1.7 cm
62 g
P/N: PEXUSB321C
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
USB powered
X VIA Labs VL820
Status Indicators
4 x USB 3.0 Type A
1 x USB-C cable - 25 cm
FCC, RoHS
1.58 cm
4.3 cm
1.7 cm
62 g
Shipping Weight
124 g
45 °C
20 - 80% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
P/N: PEXUSB321C
DPJD StarTech.com 1m Blue SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.71
DPJD StarTech.com 1m USB 3 Cable Right Angle BK In Stock £7.23
DPJD StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £7.61
DPJD StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £9.41
DPJD StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £6.39
DPJD StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £7.99
DPJD StarTech.com 6in USB 3.0 Extension Cable In Stock £5.33
DPJD StarTech.com 3ft Slim Micro USB 3.0 Cable In Stock £9.00
DPJD StarTech.com 4 Port USB 3.0 Hub - USB-C Hub In Stock £29.91
DPJD StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - White In Stock £25.84
DPJD StarTech.com 4 Port USB C Hub - C to C & A In Stock £26.36
DPJD StarTech.com 7 Port USB C Hub - C to C & A In Stock £66.79
DPJD StarTech.com 4 -Port USB-C Hub 10 Gbps - 3x USB-A & 1x USB-C In Stock £32.28
DPJD StarTech.com 3-Port USB-C Hub with LAN Port - 10Gbps In Stock £55.62
DPJD StarTech.com 3-Port USB-C Hub with SD Card Reader - 10Gbps In Stock £47.36
DPJD StarTech.com 4 -Port USB-C™ Hub 10 Gbps - 2x USB-A & 2x USB-C In Stock £42.33
DPJD StarTech.com 4 Port USB C Hub 5Gbps - 4x USB-A - Bus Powered USB 3.0 Type-C Hub - 11in Cable In Stock £25.30
DPJD StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub In Stock £125.82
DPJD StarTech.com 4 Port USB C Hub 10Gbps In Stock £128.67
DPJD StarTech.com 4-Port USB-C Hub, 100W PD In Stock £37.20
DPJD StarTech.com Portable 4pt USB-C Hub, 10Gbps In Stock £31.20
DPJD StarTech.com Industrial USB 2.0 Hub In Stock £38.22
DPJD StarTech.com 10-Port USB-C Hub Self-Powered In Stock £112.29
DPJD StarTech.com 7-Port USB-C Hub, Self-Powered In Stock £104.01
Type: USB Hub
Speed: 10Gbps
Ports: 4
