The 240W USB-C GaN Desk Charger offers a high-power charging solution for USB-C devices, supporting up to 240W with PD 3.1. It includes a 6ft NEMA 5-15P to IEC-C5 Power Cord and a Charger Base. The charger does not include a USB-C cable, allowing flexibility in cable choice. It features 4 USB-C ports (one 140W EPR) to charge up to four laptops simultaneously, supporting high-performance devices like M-Series MacBook Pros. The charger ensures optimal cooling, fast charging (0-50% in 30 minutes), and efficiency with Active Power Factor Correction. It is USB-IF protocol compatible, TUV Safety Listed, and FCC/ICES EMC certified, meeting DOE Level VI standards. Ideal for various settings, it consolidates chargers and frees up desk space. The packaging is eco-friendly, designed to minimize environmental impact.
High capacity charging
With a power output of 240 watts, this charger supports fast charging for multiple devices, ensuring quick and efficient power delivery. -
Comprehensive safety features
Includes overheat protection, overvoltage protection, and over-current protection, providing a safe charging environment for all connected devices. -
Versatile connectivity
Features four 24-pin USB-C output connectors, allowing charging of multiple devices simultaneously without compromising performance. -
Space-saving design
Incorporates GaN technology that reduces the charger's size while maintaining high power output, enhancing portability. -
Multiple security options
Equipped with Kensington and Noble Wedge security slots, ensuring devices can be securely attached and protected in various environments.
 - StarTech.com 4-Port USB-C Charger, 240W Total, Single Port 140W EPR power adapter - with surface mount bracket - 24 pin USB-C - 240 Watt
- Product Type
 - Power adapter
- Designed For
 - Notebook, tablet, mobile phone
 - 800 g
- Localisation
 - United Kingdom
- Output Connector Type
 - Total 4: 24 pin USB-C
- Voltage Required
 - AC 100-240 V
- Voltage Provided
 - 5 / 9 / 12 / 15 / 20 / 28 V
- Max Electric Current
 - 5 A
- Fast Charge Technology
 - Power Delivery 3.1
- Power Provided
 - 240 Watt
- Power Device Details
 - AC power adapter: 4 x - 24 pin USB-C - 140 W
- Cables
 - Power cable (BS 1363 to IEC-C5) - 1.8 m
 - 2-year warranty
- Product Type
 - Power adapter
- Designed For
 - 800 g
- Localisation
 - United Kingdom
- Voltage Required
 - AC 100-240 V
- Input Connectors
 - Power BS 1363
- Input Connectors Qty
 - 1
- Voltage Provided
- Output connectors
- Power Provided
 - 240 Watt
 - 5 A
 - AC power adapter: 4 x 24 pin USB-C - 140 W
 - Screw lock system, GaN Technology, VESA 100 x 100 mm, over-current protection, overheat protection, over voltage protection, Kensington security slot, Noble Wedge security slot, Kensington Nano security slot, Programmable Power Supply (PPS), rubber feet
- Material
 - Plastic
- Included Accessories
 - Mounting plate, 4 x M3x4 mm screw, 4 x M4x12 mm screw, 4 x M4x20 mm screw
- Cables Included
 - Power Delivery (EPR), PSE Mark, RCM, RoHS, UL, WEEE, cULus, DoE Level VI, FCC, IEC 62368-1, USB-IF
- Shipping Width
 - 18.5 cm
- Shipping Depth
 - 17.4 cm
- Shipping Height
 - 5.8 cm
- Shipping Weight
 - 1.1 kg
 - Limited warranty - 2 years
                        StarTech.com 1.6ft USB4 Cable, USB-C 40Gbps | In Stock | £18.91 |
