Expand a desktop or server's USB connectivity with four external USB Type-C 10Gbps ports using this PCI Express 3.0 expansion card. It provides up to 5V 3A (15W) per USB-C port for charging and syncing devices. The high bandwidth is ideal for large file transfers, high-resolution photo/video editing on external storage, and high-speed USB network adapters. If the motherboard power is insufficient, a built-in SATA power connector can supply additional power. The card is plug-and-play in Windows, Linux, and macOS and is compatible with PCI Express 3.0 x4, x8, and x16 slots. The PCIe card ships with a standard profile bracket, and a low-profile bracket is included for maximum system compatibility.
Dedicated USB Controllers
Traditional single-controller USB cards share bandwidth across all ports. With its four independent USB controllers, this USB-C expansion card enables each port to achieve up to 10Gbps, reducing bottlenecks and increasing data throughput. -
USB 3.2 Gen 2 (10Gbps) Performance
The high bandwidth makes the card ideal for transferring large files, real-time editing of high-resolution photos and videos on external storage, off-loading media from mobile devices, using high-resolution video capture devices, tethered photography equipment, or high-speed USB network adapters like 10G Ethernet copper or fiber adapter. -
Charge and Sync USB Devices
This USB PCI Express card can provide up to 5V 3A (15W) per USB-C port, enabling sync and charge of portable devices. If the motherboard can't supply enough power, a built-in SATA power connector can supply additional power to the card. -
Compatibility
The PCI Express USB card is plug-and-play in most major operating systems, including Windows, macOS, and Linux. The card is compatible with PCI Express 3.0 and x4, x8, and x16 slots. The USB expansion card also ships with a pre-installed standard profile bracket and includes a low-profile bracket for maximum compatibility.
- StarTech.com 4-Port USB Type-C PCIe Card, USB-C 10Gb, 4x Controllers, TAA - USB adapter - PCIe 3.0 x4 - USB-C 3.2 Gen 2 x 4 - TAA Compliant
- USB adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express 3.0 x4
- Ports
- 5.62 cm x 140 cm x 11.99 cm
- 120 g
- Data Link Protocol
- USB-C
- Data Transfer Rate
- 10 Gbps
- USB 1.1, USB 2.0, USB 3.0, USB 3.1, USB 3.2
- System Requirements
- Linux 2.6.31 or later, Microsoft Windows 10 / 11, Microsoft Windows Server 2019/2022 Standard, Apple macOS Sequoia 15.x, Apple macOS Sonoma
- TAA Compliant
- 2-year warranty
- USB adapter
- Form Factor
- Plug-in card
- Ports
- Connectivity Technology
- Wired
- USB-C
- 10 Gbps
- UASP, built-in SATA power connector
- 4 x USB-C - 24 pin USB-C - female (external) , 1 x SATA power (internal)
- Included Accessories
- Low-profile bracket, standard bracket
- WEEE
- TAA Compliant
- OS Required
- 5.62 cm
- 140 cm
- 11.99 cm
- 120 g
- Limited warranty - 2 years
- 0 °C
- 85 °C
- 20 - 80% RH (non-condensing)
StarTech.com 3-Port USB-C Hub with LAN Port - 10Gbps | In Stock | £53.70 |
StarTech.com 4 -Port USB-C™ Hub 10 Gbps - 2x USB-A & 2x USB-C | In Stock | £41.59 |
StarTech.com 3ft USB C Cable 10Gbps Gen2 | In Stock | £15.44 |
StarTech.com 20" USB C Cable 10Gbps Gen2 | In Stock | £13.21 |
StarTech.com 3m Active USB-C Cable, USB 3.2 | In Stock | £46.67 |
