StarTech.com 4-Port USB-A PCIe Card, 5Gbps
Quicklinx: J1K9WS00 Mfr#: P5Q4A-USB-CARD
£82.82 ex VAT
£99.38 inc VAT
The StarTech.com 4-Port USB-A PCIe Card is a versatile addition to any desktop, enhancing your PC with additional USB 3.2 Gen 1 ports. This card allows for the connection of multiple devices simultaneously, including external hard drives, HD cameras, and more, with a high-speed data transfer rate of 5 Gbps. It supports USB Power Delivery of up to 10 W, ensuring that connected devices are efficiently charged. Designed for easy installation, the card fits into PCI Express 2.0 x4 slots and includes internal power connectors for LP4 and SATA power, making it a straightforward upgrade for enhancing your system's connectivity and performance.
  • Enhanced connectivity
    The StarTech.com 4-Port USB-A PCIe Card offers expansive connectivity with four external 9-pin USB Type-A connectors, enabling multiple USB 3.2 Gen 1 device connections for a seamless user experience.
  • High-speed data transfer
    With a data transfer rate of 5 Gbps, this USB 3.2 Gen 1 interface ensures rapid file transfers, making it ideal for high-bandwidth devices such as external hard drives and HD cameras.
  • Reliable power delivery
    Features like USB Power Delivery (up to 10 W) and bus-powered capability ensure that connected devices are charged and operate efficiently, without the need for additional power sources.
  • Easy installation
    The card's Plug-and-Play form factor, designed for PCI Express 2.0 x4 slots, along with internal power connectors for LP4 and SATA power, ensures a hassle-free setup in a wide range of PC configurations.
StarTech.com 4-Port USB-A PCIe Card, USB 3.2 5Gbps, 4x USB Controllers - USB adapter - PCIe 2.0 x4 - USB 3.2 Gen 1 x 4
USB adapter
Plug-in card
Interface (Bus) Type
PCI Express 2.0 x4
PCI Specification Revision
PCIe 2.0
Ports
USB 3.2 Gen 1 x 4
1.9 cm x 16.9 cm x 12 cm
100 g
USB 3.2 Gen 1
Data Transfer Rate
5 Gbps
Renesas / Diodes Incorporated UPD720202 / PI7C9X2G608
USB 3.2 Gen 1
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Microsoft Windows Server 2022, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Linux 2.6.31 or later LTS versions only
P/N: FCREADMICRO3V2, USB315AC1M, USB3S2SAT3CB
USB adapter
Plug-in card
PCI Express 2.0 x4
PCIe 2.0
Ports
USB 3.2 Gen 1 x 4
Wired
USB 3.2 Gen 1
Data Transfer Rate
5 Gbps
UASP, bus powered, USB Power Delivery (up to 10 watt)
USB 3.2 Gen 1
Processor / Memory
4 x USB 3.2 Gen 1 - 9 pin USB Type A - female (external) , 1 x LP4 - 4 pin power - female (internal) , 1 x SATA power - 15 pin Serial ATA power - male (internal)
Low-profile bracket
WEEE
1.9 cm
16.9 cm
12 cm
100 g
Shipping Width
3.8 cm
Shipping Depth
20.7 cm
Shipping Height
14.4 cm
Shipping Weight
110 g
50 °C
5 - 90% RH (non-condensing)
J1K9 StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable In Stock £9.09
J1K9 StarTech.com 1m USB A to C Cable - USB 3.0 In Stock £6.15
J1K9 StarTech.com USB Multi-Media Card Reader In Stock £17.68
