StarTech.com 4 Port USB A Female Slot Plate Adapter
Quicklinx: 8VV4WS00 Mfr#: USBPLATE4
16 in stock
£6.24 ex VAT
£7.48 inc VAT
Add four USB 2.0 Ports to the back of your computer. The USBPLATE4 4 port USB 2.0 slot plate adapter converts the USB pins on your motherboard into four USB-A female ports, enabling you to add USB connections to the back of your PC.
The USBPLATE4 is designed and constructed for maximum durability, to ensure dependable performance.
Check your motherboard's manual for the USB pinout diagram. The USBPLATE wiring scheme is: Red=Power, Green=Signal, White=Signal, Black=Ground.
StarTech.com 4 Port USB A Female Slot Plate Adapter - USB panel - 4 pin USB Type A (F) (USBPLATE4) - USB panel - USB to 9 pin IDC
USB panel
Connector
4 x 4 pin USB Type A - female
Connector (Second End)
2 x 9 pin IDC - female
USB panel
Connector
8VV4 StarTech.com 2 Port USB A Female Slot Plate Adapter In Stock £3.85
8VV4 StarTech.com 6in Micro USB Cable - A to Micro B In Stock £3.43
8VV4 StarTech.com 2 Port USB 3.0 A Female Slot Plate Adapter In Stock £14.48
8VV4 StarTech.com 4 Port USB A Female Slot Plate Adapter In Stock £6.24
Stock Status: In stock
