StarTech.com 4 Port USB A Female Slot Plate Adapter
Quicklinx: 8VV4WS00 Mfr#: USBPLATE4
20 In Stock
£7.58 ex VAT
£9.09 inc VAT
Add four USB 2.0 Ports to the back of your computer. The USBPLATE4 4 port USB 2.0 slot plate adapter converts the USB pins on your motherboard into four USB-A female ports, enabling you to add USB connections to the back of your PC.
The USBPLATE4 is designed and constructed for maximum durability, to ensure dependable performance.
Check your motherboard's manual for the USB pinout diagram. The USBPLATE wiring scheme is: Red=Power, Green=Signal, White=Signal, Black=Ground.
  • Easy installation
    The 4 Port USB-A Female Slot Plate Adapter offers a hassle-free solution for adding USB ports to your PC, requiring no complex setup or installation. Simply connect it to the motherboard using the 9-pin IDC connector to expand your system's USB capabilities.
  • Enhanced connectivity
    With four USB Type-A female connectors, this adapter plate significantly increases your system's connectivity options, allowing for the connection of multiple USB devices simultaneously. It's perfect for systems that require additional USB ports for external hard drives, printers, and other peripherals.
  • Versatile compatibility
    Designed to be compatible with PC systems, this adapter ensures a broad compatibility range. It seamlessly integrates with your existing setup, providing reliable USB connections without the need for additional drivers or software.
StarTech.com 4 Port USB A Female Slot Plate Adapter - USB panel - 4 pin USB Type A (F) (USBPLATE4) - USB panel - USB to 9 pin IDC
USB panel
Connector
4 x 4 pin USB Type A - female
Connector (Second End)
2 x 9 pin IDC - female
USB panel
Connector
8VV4 StarTech.com 2 Port USB A Female Slot Plate Adapter In Stock £6.10
8VV4 StarTech.com 2 Port USB A Female Low Profile Slot Plate Adapter In Stock £7.22
8VV4 StarTech.com 6in Mini USB 2.0 Cable - A to Mini B In Stock £4.07
8VV4 StarTech.com 6in Micro USB Cable - A to Micro B In Stock £4.99
8VV4 StarTech.com 2 Port USB 3.0 A Female Slot Plate Adapter In Stock £18.98
8VV4 StarTech.com 4 Port USB A Female Slot Plate Adapter In Stock £7.58
