StarTech.com 4 Port USB 3.0 PCI Express PCIe Controller Card - 2 Ext 2 Int w/ SATA Power
Quicklinx: 84NXWS00 Mfr#: PEXUSB3S2E2I
Add 4 USB 3.0 ports (2 external, 2 internal motherboard header) to a computer through a PCI Express slot. The PEXUSB3S2E2I 4-Port PCI Express USB 3.0 Controller Card adds 2 external USB 3.0 ports and 2 internal USB 3.0 motherboard headers to a PCI Express-enabled computer system, with support for SuperSpeed USB 3.0 data transfer rates up to 5Gbps as well as backward compatibility with devices that rely on previous USB standards (USB 2.0, 1.x).
The adapter card features a built-on SATA power connector, which when connected to the computer power supply supports delivery of up to 900 mA of power to USB 3.0 devices (500mA for USB 2.0 devices). Plus, this PCIe USB 3.0 card is equipped with a full-profile bracket and includes an optional low-profile/half-height bracket, making it a versatile solution that can be installed in either full-sized or small form factor computer cases.
StarTech.com 4 Port USB 3.0 PCI Express PCIe Controller Card - USB adapter - PCIe - 4 ports
USB adapter
Plug-in card
Interface (Bus) Type
PCI Express
PCI Specification Revision
PCIe 2.0
12 cm x 8.3 cm x 2 cm
45 g
Ports Qty
4 ports
USB 2.0, USB 3.0
Data Transfer Rate
5 Gbps
VL800
USB 2.0, USB 3.0
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Vista / XP / 7
P/N: HBS304A24A, S3510SMU33, USB221SS, USB3S2ESATA3
USB adapter - 4 ports
Plug-in card
PCI Express
PCIe 2.0
Wired
USB 2.0, SuperSpeed USB 3.0
Data Transfer Rate
5 Gbps
USB 2.0, USB 3.0
Processor / Memory
VL800
2 x USB 3.0 - 9 pin USB Type A , 2 x USB 3.0 - 10 PIN IDC (internal)
Compatible Slots
1 x PCI Express 2.0
Low-profile bracket
FCC, RoHS
12 cm
8.3 cm
2 cm
45 g
60 °C
10 - 90%
