This portable USB 3.0 hub gives you an easy way to add four USB 3.0 Type-A ports to your laptop, with individual power switches to save power. The USB port expander plugs easily into your laptop's USB Type-A port. Plus, it's bus-powered for easy portability.
Use your existing USB 3.0 devices such as flash drives, mouse, keyboard and external hard drives. The 4-port USB 3.0 hub expands your computer's USB Type-A port into four USB 3.0 (Type-A) ports, and it's backward compatible with your older USB 2.0 devices. (USB 3.0 is also known as USB 3.1 Gen 1.)
Each port on the USB 3.0 hub has its own power switch so you can turn off devices when they're not in use. That means you can better manage power consumption for your USB devices, without having to physically disconnect the device or cable.
With its compact, lightweight design, this hub is perfect for portable use. The versatile USB to USB hub is bus-powered, with no need for an external power adapter. You can travel lighter with fewer cables to carry with you.
The 4-Port USB 3.0 hub installs automatically when you connect it to your laptop, so you can be up and running in seconds.
Versatile connectivity
Equipped with four Type-A USB 3.1 Gen 1 ports, this hub allows users to connect multiple devices simultaneously, providing convenience and efficiency for various applications. -
Reliable environmental performance
Designed to operate in temperatures ranging from 0°C to 55°C and with a humidity range of 20-80%, this hub is suitable for various working environments. -
User-friendly design
The hub features on/off switches for each port, enabling users to easily manage power to connected devices without the need for physical disconnections. -
Compatible with multiple standards
This device is compliant with USB 1.1, USB 2.0, USB 3.0, and USB 3.1 Gen 1 standards, ensuring broad compatibility with a wide range of peripherals. -
Compact and desktop-friendly
With a compact form factor, this hub fits perfectly on any desktop, facilitating easy access to all connections without occupying excessive space.
- StarTech.com 4 Port USB 3.0 Hub, USB-A to 4x USB 3.0 Type-A with Individual On/Off Port Switches, SuperSpeed 5Gbps USB 3.1/USB 3.2 Gen 1, USB Bus Powered, Portable, 9.8" Attached Cable - Windows/macOS/Linux (HB30A4AIB) - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x USB 3.1 Gen 1
- USB powered, on/off switches
- USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 1
- 3.49 cm x 8.5 cm x 1.92 cm
- 50 g
- Black
- System Requirements
- Apple MacOS, Linux, Microsoft Windows
- 2-year warranty
- Designed For
- P/N: HB30C4AIB
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- 4 x USB 3.1 Gen 1
- Processor
- X VIA Labs VL817
- Status Indicators
- Power
- 4 x USB 3.1 Gen 1 Type A
- Black
- Cables Included
- 1 x USB 3.1 cable - 25 cm
- FCC, RoHS, UASP (USB Attached SCSI Protocol)
- OS Required
- 3.49 cm
- 8.5 cm
- 1.92 cm
- 50 g
- Shipping Weight
- 58 g
- Limited warranty - 2 years
- 0 °C
- 55 °C
- 20 - 80% (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
- Designed For
- P/N: HB30C4AIB
StarTech.com 1m Blue SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.81 |
StarTech.com 1m USB 3 Cable Right Angle BK | In Stock | £6.81 |
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £8.07 |
StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £7.30 |
StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £7.57 |
StarTech.com 6in USB 3.0 Extension Cable | In Stock | £5.41 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £10.18 |
StarTech.com 4 Port USB 3.0 Hub - USB-C Hub | In Stock | £31.46 |
StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - White | In Stock | £39.55 |
StarTech.com 4 Port USB C Hub - C to C & A | In Stock | £27.54 |
StarTech.com 7 Port USB C Hub - C to C & A | In Stock | £69.09 |
StarTech.com 4-pt USB Hub with On/Off Switches | In Stock | £45.45 |
StarTech.com 7-pt USB Hub with On/Off Switches | In Stock | £64.96 |
