StarTech.com 4 Port USB 3.0 Hub USB-C to 4x USB-A
Quicklinx: DYDNWS00 Mfr#: HB30C4AB
Type: Docking station
Interface: SuperSpeed USB 3.0
Speed: 5Gbps
Ports: 4
Form Factor: External
35 In Stock
£30.53 ex VAT
£36.63 inc VAT
Turn your laptop's USB Type-C port into four USB Type-A ports (5Gbps) using this bus-powered hub. Here's a must-have accessory if you have a USB-C equipped computer but need more USB-A ports. This portable USB 3.0 hub expands your laptop or desktop connectivity by adding four USB Type-A ports through a single USB Type-C or Thunderbolt 3 port. And, because it's USB bus-powered, you don't need to connect an external power adapter, which makes travel more convenient and workstations less cluttered.
If you're looking to extend the life of your existing USB-A peripheral devices, then this hub is the perfect solution. By converting your computer's USB-C port into four USB-A ports, you can continue to use all of your existing USB 3.0 devices such as flash drives, external hard drives, and printers (USB 3.0 is also known as USB 3.1 Gen 1). Now you can save money by avoiding the added cost and hassle of purchasing new USB-C equipped peripherals.
With its compact and lightweight design, this USB hub is tailored for mobility. You can easily tuck it into your laptop bag when traveling, which makes it easy to expand your connectivity almost anywhere you need to.
Plus, with a small-footprint design the 4-port hub takes up minimal desk space when connected in your work area.
This versatile USB-C hub is bus-powered, which means it draws its power directly from your computer's USB-C port. This means there are fewer cables to carry with you when you travel because it doesn't need an external power adapter.
This USB hub is multi-platform compatible, which means it will work with a wide range of laptops. It also works with a range of operating systems such as Windows, Mac, Linux and Chrome OS . It installs automatically once you connect it to your laptop, so you can be up and running in seconds.
  • Versatile connectivity
    This hub provides four SuperSpeed USB 3.0 ports, allowing users to connect multiple devices such as external drives, keyboards, and mice.
  • Compact design
    The hub's portable form factor makes it easy to carry in a laptop bag or backpack, ensuring users can expand device connectivity wherever they go.
  • Plug-and-play support
    The hub features Plug-and-Play capabilities, meaning it requires no drivers or software installation to function.
  • Robust compatibility
    Supports USB 1.1, USB 2.0, and USB 3.0 standards, ensuring compatibility with a wide range of devices including legacy equipment.
  • Reliable performance
    Built to operate in a variety of conditions, this hub can function in temperatures ranging from 0 °C to 45 °C, making it suitable for both home and office environments.
StarTech.com 4-Port USB-C Hub - Portable USB-C to 4x USB-A Hub - Bus-Powered USB 3.1 Gen 1 Type-C Hub - USB 3.0 Port Expander (HB30C4AB) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
USB powered
USB 1.1, USB 2.0, USB 3.0, USB 3.1
4.1 cm x 8 cm x 1.5 cm
35 g
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
USB powered
X VIA Labs VL812
1 x USB-C , 4 x USB 3.0 output Type A
1 x SuperSpeed USB-C cable - 14.6 cm
Plug and Play, FCC, RoHS, WEEE, RCM
4.1 cm
8 cm
1.5 cm
35 g
45 °C
10 - 85% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
DYDN StarTech.com Rugged Hard Drive Enclosure In Stock £32.20
DYDN StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £8.64
DYDN StarTech.com 3m 10ft USB 3.0 A to A Cable In Stock £7.17
DYDN StarTech.com 6ft USB-C to A Cable - USB 2.0 In Stock £11.44
DYDN StarTech.com 4 Port USB 3.0 C Hub - C to A In Stock £36.34
DYDN StarTech.com 4-Port USB-C Hub - USB 3.1 In Stock £33.92
DYDN StarTech.com 4-Port USB 3.0 Hub with On/Off In Stock £23.64
DYDN StarTech.com 4-Port USB-C Hub, 100W PD In Stock £37.13
DYDN StarTech.com Portable 4pt USB-C Hub, 10Gbps In Stock £31.13
Speed: 5Gbps
Ports: 4
