StarTech.com 4 Port USB 3.0 Hub 5Gbps - 4x USB-A - USB Bus Powered USB
Quicklinx: G7THWS00 Mfr#: HB30AM4AB
Type: USB
Ports: 4
Data Transfer Rate: [N/A]
Managed: No
POE: No
£22.04 ex VAT
£26.44 inc VAT
USB A Hub - SuperSpeed USB 5Gbps (USB 3.0/3.1/3.2) - Built-in 11" Host Cable
This 4 Port USB Hub enables you to connect four SuperSpeed USB 3.2 Gen 1 (5 Gbps) peripherals to your USB-A laptop or computer, an ideal solution for adding USB ports to a device that has limited USB ports available. It features a wrap-around cable manager, allowing you to tuck away the built-in cable for easy portability.
Note: USB 3.2 Gen 1 (5 Gbps) is also know as USB 3.1 Gen 1 (5 Gbps), and USB 3.0 (5 Gbps).
Expands the Connectivity of Your Computer
With this USB hub you can connect four USB-A devices to a single USB-A port on your host device. The USB Type-A hub shares up to 4.5W (5V/900mA) of power between connected devices, making it an ideal solution for connecting SSD/thumb drives, data storage, keyboards, mice, web cams and USB headsets. The USB hub is backward compatible with USB 2.0 (480 Mbps).
Highly Portable and Sleek
Featuring a durable plastic housing that's lightweight, and a sleek warp-around cable management system, this USB hub is the perfect travel companion for your laptop. Its small footprint ensures it will store easily in your laptop bag, and the wrap-around cable manager prevents tangles, ensuring easy accessibility. The USB hub is bus powered so there's no bulky external power adapter.
Wide Device Compatibility
The USB hub is OS independent ensuring support on a wide range of platforms including Windows, macOS, Linux, iPadOS, Chrome OS and Android. The built-in host cable is 11 in. (28 cm) long, providing enough length to easily integrate into any workstation, reaching your host device even when it's placed on a laptop riser or stand. The USB-A host connection works with any USB Type-A laptop, or 2-in-1, such as Surface Pro 7, Surface Book, MacBook, XPS or X1 Carbon.
HB30AM4AB is backed by a StarTech.com 2-year warranty and free lifetime 24/5 multi-lingual North American based technical support. StarTech.com has been the IT professionals' choice for over 30 years.
  • Expands the connectivity of your computer
  • Highly portable and sleek
  • Wide device compatibility
StarTech.com 4 Port USB 3.0 Hub, 4x USB-A, 5Gbps Laptop/Desktop USB Type-A Hub, USB Bus Powered, 11" Long Cable with Cable Management (HB30AM4AB) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB 3.2 Gen 1
Plastic housing
USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 1, USB 3.2 Gen 1
5 cm x 13.5 cm x 2 cm
75 g
Black, space grey
Apple MacOS, Linux, Microsoft Windows, Google Chrome OS
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB 3.2 Gen 1
Plastic housing
X Realtek Semiconductor RTS5411E
4 x USB 3.2 Gen 1 Type A
Black, space grey
1 x USB 3.2 cable - 28 cm
FCC, RoHS, WEEE, RCM, UASP (USB Attached SCSI Protocol)
5 cm
13.5 cm
2 cm
75 g
Shipping Width
17 cm
Shipping Depth
14.2 cm
Shipping Height
3 cm
Shipping Weight
132 g
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
G7TH StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £7.61
G7TH StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £9.41
G7TH StarTech.com 3ft Slim Micro USB 3.0 Cable In Stock £9.00
G7TH StarTech.com 1 m / 3.3 ft USB 2.0 to USB C Cable – Black In Stock £8.64
G7TH StarTech.com 4 Port USB C Hub - 3 USB-A/1 USB-C (5Gbps USB 3.0) - 11.2" Cable In Stock £43.12
G7TH StarTech.com 4 Port USB C Hub 5Gbps - 4x USB-A - Bus Powered USB 3.0 Type-C Hub - 11in Cable In Stock £25.28
Type: USB
Ports: 4
Managed: No
POE: No
