StarTech.com 4 Port USB 3.0 C Hub - C to A
Quicklinx: CWSHWS00 Mfr#: HB30C4AFS
8 In Stock
£37.97 ex VAT
£45.56 inc VAT
Standard delivery Delivered within 3-5 working days
Turn your laptop's USB Type-C port into four USB Type-A charge-and-sync ports (5Gbps). This compact USB 3.0 hub expands your connectivity by adding four USB Type-A ports through a single USB Type-C or Thunderbolt 3 port. It includes a 20-watt power adapter, so you have the versatility to connect power-hungry USB devices, and you can fast-charge your mobile devices using the USB charge-and-sync ports.
By converting your computer's USB-C port into four USB-A ports, you can continue to use all of your existing USB 3.0 devices such as flash drives, external hard drives, and printers (USB 3.0 is also known as USB 3.1 Gen 1). Now you can save money and time by avoiding the added cost and hassle of purchasing new USB-C equipped peripherals.
With its compact and lightweight casing, this USB hub is designed for mobility. You can easily tuck it into your laptop bag when traveling, which makes it easy to expand your connectivity almost anywhere you need to.
The 4-port hub takes up minimal desk space when connected in your work area, with a small-footprint design.
With four charge-and-sync ports, this hub helps ensure that your mobile devices are charged and ready to use when you need them. The self-powered hub features USB ports that deliver more power than traditional USB ports, so you can charge your devices faster. The charge provided depends on the number of devices connected and the amount of electrical current each device draws.
This self-powered USB 3.0 hub comes with an external power adapter to support power-hungry USB devices. This means you can reliably connect and use larger external hard drives and enclosures.
This four-port USB hub is multi-platform compatible, which means it will work with a wide range of laptops. It also works with a range of operating systems such as Windows, Mac, Linux and Chrome OS . It installs automatically once you connect it to your laptop, so you can be up and running in seconds.
  • Efficient multiple device connectivity
    Equipped with four USB 3.0 output ports, this hub facilitates simultaneous connections for a variety of peripherals, enhancing productivity.
  • Fast data transfer rates
    The hub supports SuperSpeed USB 3.0, allowing data transfer speeds of up to 5 Gbps, which helps reduce wait times when moving large files.
  • Compatibility with Mac systems
    Designed to work seamlessly with Mac devices, this hub ensures that users experience straightforward functionality without complex installations.
  • Compact and portable design
    The hub includes an 11.4 cm SuperSpeed USB-C cable, making it easy to connect to devices without clutter and enhancing portability for on-the-go use.
  • Reliable environmental performance
    With a wide operating temperature range and humidity resilience, this hub performs effectively in various conditions, ensuring consistent reliability.
StarTech.com 4 Port USB C Hub with 4x USB-A Ports USB 3.0 (USB 3.1/3.2 Gen 1 SuperSpeed 5Gbps), USB Bus or Self Power, Portable USB Type-C to USB-A BC 1.2 Charging Hub w/Power Adapter - Windows/macOS/Linux (HB30C4AFS) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
USB powered
USB 1.1, USB 2.0, USB 3.0, USB 3.1
4 cm x 7.5 cm x 1.3 cm
40 g
Apple MacOS, Linux, Microsoft Windows, Google Chrome OS
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
USB powered
X Genesys Logic GL3523
Status Indicators
4 x USB 3.0 output Type A , 1 x USB 3.0 input Type C
1 x SuperSpeed USB-C cable - 11.4 cm
Plug and Play, FCC, RoHS, WEEE, USB Battery Charging Specification Rev. 1.2
4 cm
7.5 cm
1.3 cm
40 g
60 °C
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
CWSH StarTech.com 0.5m White Micro USB Cable - A to Micro B In Stock £5.24
CWSH StarTech.com 4 Port USB 3.0 Hub - USB-C Hub In Stock £31.46
CWSH StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £9.09
CWSH StarTech.com 3m 10ft USB 3.0 A to A Cable In Stock £7.51
CWSH StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop In Stock £52.58
CWSH StarTech.com 6ft USB-C to A Cable - USB 2.0 In Stock £11.44
CWSH StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - White In Stock £39.55
CWSH StarTech.com 4-Port USB-C Hub, 100W PD In Stock £38.80
CWSH StarTech.com Portable 4pt USB-C Hub, 10Gbps In Stock £32.62
