StarTech.com 4 Port USB 3.0 C Hub - C to A
Quicklinx: CTJCWS00 Mfr#: HB30C4ABW
Type: USB Hub
Interface: SuperSpeed USB 3.0, USB 3.1 Type C
Speed: 5Gbps
Ports: 4
Form Factor: External
14 In Stock
£30.05 ex VAT
£36.06 inc VAT
Turn your laptop's USB Type-C port into four USB Type-A ports (5Gbps) using this bus-powered hub. This portable USB 3.0 hub expands your laptop or desktop connectivity by adding four USB Type-A ports through a single USB Type-C or Thunderbolt 3 port. And, because it's USB bus-powered, you don't need to connect an external power adapter, which makes travel more convenient and workstations less cluttered.
With its compact design, you can take this portable USB-C hub anywhere you go. It's easy to tuck into your laptop bag and only takes up a small amount of desk space when you connect it to your workstation.
Plus, the hub is bus powered, which means it draws power directly from the USB-C port on your computer. This makes it even more portable because there are fewer cables to carry with you when you travel and it doesn't need an external power adapter.
If you're looking to extend the life of your existing USB-A peripheral devices, then this hub is the perfect solution. By converting a single USB-C port into four USB-A ports, you can continue to use all of your existing USB 3.0 devices such as flash drives, external hard drives, and printers. Now you can save money by avoiding the added cost and hassle of purchasing new USB-C equipped peripherals.
This USB hub is multi-platform compatible, which means it will work with a wide range of laptops. It also works with a range of operating systems such as Windows, Mac, Linux and Chrome OS . It installs automatically once you connect it to your laptop, so you can be up and running in seconds.
StarTech.com 4 Port USB C Hub with 4x USB-A Ports (USB 3.0 SuperSpeed 5Gbps), USB Bus Powered, Portable/Laptop USB-C to USB-A Adapter Hub, USB 3.1 Gen 1/USB 3.2 Gen 1 Type-C Hub, White - Windows/macOS/Linux (HB30C4ABW) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
USB powered
USB 1.1, USB 2.0, USB 3.0
4.1 cm x 8 cm x 1.5 cm
35.2 g
White
Apple MacOS, Linux, Microsoft Windows, Google Chrome OS
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
USB powered
X VIA VL812
4 x USB 3.0 output Type A , 1 x USB 3.0 input Type C
White
Plug and Play, FCC, RoHS
4.1 cm
8 cm
1.5 cm
35.2 g
45 °C
10 - 85% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
CTJC StarTech.com 4 Port USB 3.0 Hub - USB-C Hub In Stock £30.96
CTJC StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £9.09
CTJC StarTech.com 3m 10ft USB 3.0 A to A Cable In Stock £7.51
CTJC StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop In Stock £52.58
CTJC StarTech.com 6ft USB-C to A Cable - USB 2.0 In Stock £11.44
CTJC StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - White In Stock £38.95
CTJC StarTech.com 4 Port USB 3.0 C Hub - C to A In Stock £30.05
CTJC StarTech.com 4 Port USB 3.0 C Hub - C to A In Stock £37.97
CTJC StarTech.com 4 Port USB C Hub - C to C & A In Stock £27.74
CTJC StarTech.com 7 Port USB C Hub - C to C & A In Stock £68.01
CTJC StarTech.com 7 Port USB-C Hub - C to C & A In Stock £71.66
CTJC StarTech.com 4-Port USB-C Hub - USB 3.1 In Stock £34.92
CTJC StarTech.com 4-Port USB 3.0 Hub with On/Off In Stock £24.36
CTJC StarTech.com 4-Port USB-C Hub, 100W PD In Stock £38.20
CTJC StarTech.com Portable 4pt USB-C Hub, 10Gbps In Stock £32.12
Type: USB Hub
Interface: USB 3.1 Type C
Speed: 5Gbps
Ports: 4
