Connect four USB 2.0 devices away from your computer over Cat5 (40m) or Cat6 (50m). This 4-port USB 2.0 extender is an easy and inexpensive solution for creating workspace freedom. Now you can extend the distance of your USB 2.0 devices over a single Ethernet cable, up to 130ft (40m) over Cat5, or 165ft (50m) over Cat6.
Overcome the 16ft USB cable length limitation to create a more flexible and efficient workspace. Now you can place up to four USB devices in remote locations away from the host computer system. Position your hard drive enclosure, printer, scanner, webcam and other popular peripherals right where you need them, to save time and enhance your productivity.
Gain quick access to the USB devices you use most frequently. Often on the go? Use the two top ports for fast, easy connections to portable devices like flash drives, smartphones and tablets. Plus, you still have two front-facing ports for printers or other devices requiring a more permanent set-up.
The versatile USB2004EXTV supports Windows, Mac and Linux systems. Set-up is easy with no additional drivers or software required, and the extender is backward compatible with USB 1.1 and 1.0 peripherals.
- StarTech.com 4-Port USB 2.0 Extender - 165ft (50m) USB Over Cat5/Cat6 Extender - Compact USB 2.0 Over Ethernet Extender (USB2004EXTV) - USB extender - USB 2.0
- USB extender
- Ports Qty
- 4
- Form Factor
- External
- Data Transfer Rate
- 480 Mbps
- Data Link Protocol
- USB 2.0
- Max Transfer Distance
- 50 m
- Power
- AC 120/230 V
- 5.2 cm x 8 cm x 2.2 cm
- 325 g
- 2-year warranty
- Designed For
- P/N: SVA5N3NEUA
- USB extender
- Form Factor
- External
- Black
- Ports Qty
- 4
- Connectivity Technology
- Wired
- USB 2.0
- 480 Mbps
- 50 m
- 1 x USB 2.0 - mini-USB Type B , 4 x USB 2.0 - Type A
- Cables Included
- 1 x USB cable , 1 x network cable
- FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 10 Watt
- 5.2 cm
- 8 cm
- 2.2 cm
- 325 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 0 - 80%
- Designed For
- P/N: SVA5N3NEUA
