StarTech.com 4-port USB 2.0 Over Cat5 or Cat6 Extender (50m)
Quicklinx: B681WS00 Mfr#: USB2004EXTV
Type: USB Hub
Interface: USB 2.0
Speed: 480Mbps
Ports: 4
Form Factor: External
Hurry, only 3 left in stock!
£146.84 ex VAT
£176.20 inc VAT
Connect four USB 2.0 devices away from your computer over Cat5 (40m) or Cat6 (50m). This 4-port USB 2.0 extender is an easy and inexpensive solution for creating workspace freedom. Now you can extend the distance of your USB 2.0 devices over a single Ethernet cable, up to 130ft (40m) over Cat5, or 165ft (50m) over Cat6.
Overcome the 16ft USB cable length limitation to create a more flexible and efficient workspace. Now you can place up to four USB devices in remote locations away from the host computer system. Position your hard drive enclosure, printer, scanner, webcam and other popular peripherals right where you need them, to save time and enhance your productivity.
Gain quick access to the USB devices you use most frequently. Often on the go? Use the two top ports for fast, easy connections to portable devices like flash drives, smartphones and tablets. Plus, you still have two front-facing ports for printers or other devices requiring a more permanent set-up.
The versatile USB2004EXTV supports Windows, Mac and Linux systems. Set-up is easy with no additional drivers or software required, and the extender is backward compatible with USB 1.1 and 1.0 peripherals.
  • Go the extra distance for increased productivity
  • Port location enables fast and easy connections
  • Supports any operating system and older devices
    The versatile USB2004EXTV supports Windows ; Mac and Linux systems. Set-up is easy with no additional drivers or software required, and the extender is backward compatible with USB 1.1 and 1.0 peripherals. This product is TAA compliant and backed by a Startech.com 2-year warranty with free lifetime technical support.
StarTech.com 4-Port USB 2.0 Extender - 165ft (50m) USB Over Cat5/Cat6 Extender - Compact USB 2.0 Over Ethernet Extender (USB2004EXTV) - USB extender - USB 2.0
USB extender
Ports Qty
4
External
Data Transfer Rate
480 Mbps
USB 2.0
Transmission Medium
CAT 5/6
Max Transfer Distance
50 m
AC 120/230 V
5.2 cm x 8 cm x 2.2 cm
325 g
P/N: SVA5N3NEUA
USB extender
External
Ports Qty
4
Wired
USB 2.0
Data Transfer Rate
480 Mbps
50 m
1 x USB 2.0 - mini-USB Type B , 4 x USB 2.0 - Type A
1 x USB cable , 1 x network cable
FCC, RoHS
External power adapter
AC 120/230 V
10 Watt
5.2 cm
8 cm
2.2 cm
325 g
50 °C
0 - 80%
P/N: SVA5N3NEUA
B681 StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £31.13
B681 StarTech.com 1 Port USB over Cat5 / Cat6 Ethernet Extender - up to 131ft (40m) In Stock £102.87
B681 StarTech.com 4-port USB 2.0 Over Cat5 or Cat6 Extender (50m) In Stock £146.84
B681 StarTech.com 1 Port USB 2.0 Extender Kit In Stock £127.12
B681 StarTech.com DC Power Adapter - 5V, 3A In Stock £12.21
B681 StarTech.com 4-Port USB 2.0 Extender Hub In Stock £322.88
B681 StarTech.com USB 2.0 Extender, 492ft In Stock £188.95
Type: USB Hub
Interface: USB 2.0
Speed: 480Mbps
Ports: 4
