StarTech.com 4-Port USB 2.0 Hub, Compact
Quicklinx: J1LRWS00 Mfr#: ST4200MINI2-USB-HUB
41 In Stock
£6.54 ex VAT
£7.84 inc VAT
  • Convenient connectivity
    This hub features four USB 2.0 ports that allow multiple devices to be connected at once, making it ideal for users who need to expand their connection options.
  • Efficient data transfer
    With a data transfer rate of 480 Mbps, this hub ensures swift communication between your devices, enhancing productivity.
  • Portable design
    The small and lightweight structure of the hub makes it easy to carry, fitting seamlessly into travel bags for on-the-go connectivity.
  • Rugged environmental resilience
    Designed to operate in a wide temperature range from 0°C to 45°C, this USB hub is suitable for various environments, whether in an office or while traveling.
  • Safety features
    Equipped with over-current protection, this hub safeguards connected devices from potential damage caused by unexpected power surges.
