StarTech.com 4-Port USB 2.0 Extender Hub
Quicklinx: GFJ7WS00 Mfr#: USB2004EXT100
Type: Modules
£340.33 ex VAT
£408.39 inc VAT
USB Extender Over CAT5e/CAT6/CAT7 - Rugged Enclosure - 2-Year Warranty.
  • Hi-Speed USB Performance
    With data bandwidth of up to 480Mbps and no software installation required, the USB extender over Cat5e, Cat6, or Cat7 network cabling offers a fast, easy, and versatile solution for business or commercial applications with durable metal housing, an included surface-mounting bracket kit and simple plug-and-play installation. Plus, the 330 ft. (100 m) USB extender provides up to the full 500 mA of power (with the use of an external power adapter at the remote end) allowing for greater compatibility with bus-powered USB devices.
  • Compatible with USB 2.0/1.1/1.0 Devices
    Connecting low-speed peripherals or HID devices isn't a problem. This versatile USB over network extender is backward compatible with legacy USB 1.0/1.1 devices, so you can access up to four different types of USB devices from your remote location, far away from the host computer.
  • The Choice of IT Pros Since 1985
    StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales USB2004EXT100 is backed by a StarTech.com 2-year warranty and free lifetime 24/5 North American based, multi-lingual support.
StarTech.com 4 Port USB 2.0 Extender Hub over Single CAT5e/CAT6 Ethernet Cable (RJ45), 330ft (100m), USB Extender Adapter, Externally Powered, 480 Mbps, Metal USB Extender Kit - Power/Link LEDs (USB2004EXT100) - USB extender - USB 2.0
USB extender
External
Australia, Japan, New Zealand, North America, United Kingdom, Europe
Data Transfer Rate
480 Mbps
USB 2.0
Transmission Medium
CAT 5e/6
Max Transfer Distance
100 m
AC 100-240 V
6 cm x 10 cm x 2.2 cm
143 g
USB extender
External
Wired
USB 2.0
Data Transfer Rate
480 Mbps
100 m
Status Indicators
Status
Rugged
USB 2.0
4 x USB 2.0 - Type A , 1 x USB 2.0 - Type B
4 rubber feet
2 x mini-USB to USB cable - 1.5 m , 1 x network cable - 1.5 m
Plug and Play, FCC, RoHS, WEEE
External power adapter
Installed Qty
1
AC 100-240 V
10 Watt
6 cm
10 cm
2.2 cm
143 g
Shipping Width
23.5 cm
Shipping Depth
15.3 cm
Shipping Height
6.5 cm
Shipping Weight
716 g
0 - 80% RH
Type: Modules
