StarTech.com 4 Port Triple Monitor DVI USB KVM Switch with Audio & USB 2.0 Hub
Quicklinx: 8G5TWS00 Mfr#: SV431TDVIUA
Type: KVM / audio / USB switch
Connectivity: KVM
Ports: 4
£205.12 ex VAT
£246.14 inc VAT
Switch between four triple head computers, while sharing three DVI displays, speakers & mic, USB Keyboard/Mouse, and USB 2.0 peripherals. The SV431TDVIUA 4-Port Triple Monitor DVI USB KVM Switch allows 4 PCs (each with 3 DVI video outputs) to share monitors, 1 microphone and set of speakers, 1 keyboard and 1 mouse, as well as an additional USB 2.0 peripheral such as an external hard drive, thumb drive, printer, or webcam.
The Triple DVI KVM switch enables you to switch back and forth between 4 multi DVI PCs at the touch of a button, while maintaining professional-level video quality on all monitors at resolutions up to 1920x1200. The triple DVI KVM switch also features an integrated USB hub port which allows USB 2.0 peripherals to be shared between attached systems, eliminating duplicate peripheral costs and offering the convenience of sharing stored data between PCs.
While both DVI-I (analog mode) and DVI-D (digital only) are supported by the KVM, both source PCs must output the same signal type for proper switching. It is recommended, wherever possible, to use DVI-D cables across all PC to KVM and KVM to Console connections.
StarTech.com 4 Port Triple Monitor DVI USB KVM Switch with Audio & USB 2.0 Hub - Multi Monitor KVM - USB DVI KVM Switch (SV431TDVIUA) - KVM / audio / USB switch - 4 ports
Subtype
KVM
Ports
4 x KVM / audio / USB
KVM Users Qty
1 local user
HDCP compliant, built-in 4-port USB 2.0 hub
AC 120/230 V
21.9 cm x 13 cm x 8.1 cm
1.5 kg
3-year warranty
P/N: SV431RACK, SVA12M2NEUA, SVA12M5NA
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1200
Status Indicators
Port status
4 x USB 2.0 Type B , 12 x DVI-I , 4 x audio / headphones mini-jack , 4 x microphone input mini-jack , 3 x DVI-I , 4 x USB 2.0 Type A , 1 x audio / headphones mini-jack , 1 x microphone input mini-jack
External power adapter
AC 120/230 V
UL, FCC, RoHS
21.9 cm
13 cm
8.1 cm
1.5 kg
Limited warranty - 3 years
0 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
8G5T StarTech.com 6 ft 3.5mm Stereo Audio Cable - M/M In Stock £4.64
8G5T StarTech.com 6 ft 3.5mm Stereo Extension Audio Cable - M/F In Stock £4.82
8G5T StarTech.com 12 ft PC Speaker Extension Audio Cable In Stock £5.33
8G5T StarTech.com 6ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £7.64
8G5T StarTech.com 15ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £6.92
8G5T StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £233.24
8G5T StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £243.20
8G5T StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £114.49
8G5T StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £128.11
8G5T StarTech.com 3.5 mm to 3.5 mm Audio Coupler - Female to Female In Stock £5.40
8G5T StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.50
8G5T StarTech.com DisplayPort USB KVM Switch In Stock £287.60
8G5T StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) In Stock £22.12
8G5T StarTech.com DC Power Adapter - 12V, 2A In Stock £11.71
8G5T StarTech.com DC Power Adapter - 12V, 5A In Stock £41.02
Connectivity: KVM
Ports: 4
